Twin Turbo LSX Datsun 280Z
Old 05-01-2015, 07:42 AM
  #861
coltboostin's Avatar
Love the car!!!! Perfect lines!
Hate that your going Auto. But, it will 1/4 much faster (obviously). I would love to here an honest review about how you feel about the swap to auto at the end of the season as far as driver enjoyment.
Old 05-01-2015, 07:56 AM
  #862
oscs's Avatar
Originally Posted by RonA
Did you happen to hear from anyone how much power you could actually put through overdrive on a well built 4L80E? I had a new one built last winter for my Z and just received 5 boxes of Holley EFI stuff including the 4L80 trans harness, so I've sort of commited to running it. I assume the Dominator could be programmed to back the boost off in overdrive.
Yes and the answer i got from everyone was that OD is for cruising only. Not a single builder would put a number on it. They basically deemed it Taboo.
Old 05-02-2015, 09:42 PM
  #863
twinturbo496's Avatar
Its not the power level that is the issue... It is the shift from 3 to 4 at very high rpm the transmission builders don't like...
With stock guts it held around 700 whp in od fine for me.
Old 05-02-2015, 10:35 PM
  #864
oscs's Avatar
I never have such luck with anything I've owned. I didn't want to be constantly worrying about a $5k transmission possibly failing. For the 7ish grand it cost me for the glide and OD unit I bought a guarantee and piece of mind.
Old 05-02-2015, 11:55 PM
  #865
RonA's Avatar
Seems like a wise move to me.
Old 05-05-2015, 03:55 PM
  #866
RonA's Avatar
Did you happen to get a weight for the Powerglide/GV combo? Looks like it's probably around 40-50lbs lighter than a 4L80E.
Old 05-05-2015, 04:29 PM
  #867
oscs's Avatar
The glide showed up today and the GV unit still hasn't shipped...
Old 05-05-2015, 04:36 PM
  #868
rkreigh's Avatar
make your full power runs in 3rd. the od will only take so many hard upshifts as it's not designed for it and can only be beefed so much
I've made a 4l65e live at 800 at the tire with careful driving in 4th
biggest problem is aggressive throttle that forces a downshift
if you need to go fast, slow down, shift to 3rd, and let er rip
od won't gain you a thing beyond the repairs
Old 05-07-2015, 11:23 AM
  #869
RonA's Avatar
I'm looking forward to hearing how the glide/gv set up works. My motor is finally starting to take shape and will hopefully be running n/a by the end of summer. I'd like to try getting into the 9's before adding the charger/chargers so I'll leave the 4l80 in for now.
Old 05-07-2015, 12:57 PM
  #870
oscs's Avatar
Im excited to get it going. The GV unit shipped yesterday and shows to be at my door step Monday. I still cant believe this tiny *** Transmission is capable of holding 1200+ HP
BTW does anyone know the thread sizes for the in/out ports on the housing? Also which one is input/output?
Old 05-07-2015, 01:23 PM
  #871
RonA's Avatar
I've been looking at them and some of the HP capabilities are crazy. I had no idea that the transmission I hated in my old Impala SS that I bought for $125 back in 1973 would be on my wish list 40 years later. Well, not exactly the same.
Old 05-11-2015, 09:09 AM
  #872
oscs's Avatar
That's the way it goes sometimes.
Old 05-11-2015, 09:16 AM
  #873
oscs's Avatar
Update: Motor is back together and waiting to go back in. GV unit is on the truck for todays delivery.
While i was waiting i started to redo my my fuel system as i had eBay rubber/SS braid fuel lines. I felt like this was a ticking time bomb especially since ive been running E85 a lot more lately. A friend of mine gets distributor pricing from AeroFlow in AUS so i ordered a bunch of Black anodized Aluminum tubing so i could re do my long straights. I also went ahead and ordered some black Teflon hose to connect to the motor and cover some of the tricky areas. I have to say that Aluminum is AWESOME to work with.. The **** bends anyway i want and flares are just a joke.. The stuff is awesome to work with. I will get some updated pictures soon but rest assured there is progress in the back ground. Oh and I also switch to solid motor mounts.
Just before we pulled it out.
Old 05-11-2015, 10:52 AM
  #874
91 240's Avatar
looks damn good man! Good luck with the new trans.
where abouts in Cypress do you live? my pops lives off of Telge. Not that i'm stalking or anything , just curious when we make our next trip to visit. wouldn't mind check it out if you're ok with it.
Old 05-11-2015, 12:33 PM
  #875
oscs's Avatar
Thanks man. Give me a shout next time your in town if you want to check out the car. Im right down the road @ meushcke
Old 05-11-2015, 09:25 PM
  #876
oscs's Avatar
31.5" from bell housing to tail housing. It weights 179lbs Dry with the flex plate and torque converter. 171lbs dry without the flex plate.
Old 05-12-2015, 12:12 AM
  #877
Forcefed86's Avatar
Pretty Fancy! How do you control the OD gears?
Old 05-12-2015, 08:07 AM
  #878
oscs's Avatar
I would tend to agree with you sir! There are a few ways but im using a foot switch.
Old 05-12-2015, 08:42 AM
  #879
Mongoose350's Avatar
So I guess it's 1-2 for the track and then you can use OD1-OD2 (3-4) for street driving? That's pretty cool.
Old 05-12-2015, 08:56 AM
  #880
oscs's Avatar
1-od-2-od it is essentially a 4 speed W/OD at this point. Difference here being that i can actually go WOT in OD. Im going to try and find a 4:10 or even shorter rear gear to utilize these OD capabilities as much as possible.
Quick Reply: Twin Turbo LSX Datsun 280Z
