Stock lq4 boost ??
What was your MPH?
I have an 02 lq4 with 115k, at 15 psi on pump/meth keep the AFR and timming low, Im at 10.9 and 12 degrees. If you have a low mileage engine you might want to open the ring gap but Id do studs and gaskets while the engines out. I did rod bolts, wished I wouldn't of sucks to pull apart a 110K engine with every thing looking as good as new and wonder if the new torque on the rod bolts changed anything.
Turbo size depending what you want to do with the car. But personally i would go with a custom spec'd cam and a S480 its cheap and you will make as much power as you will need for a street car if you dont want to spend the money look for a used TU2 cam that made plenty of power on my old set up.
