boost and pump gas
Old Jan 28, 2014 | 08:43 AM
oscs's Avatar
I still don't understand why you all are trying to get this guy into a meth kit.. His goal is 550rwhp
Old Jan 28, 2014 | 10:20 PM
transaminator99's Avatar
i would consider meth if its necessary ... i guess i never took the time to fully understand it i know that the iat sensor controls timing according to air temp but stupid question from me is does the meth just spray the iat sensor to give it a different reading or does it actually go into the combustion chamber and cool things down? and i will be running on3's bigger intercooler idk im on a 5k budget when taxes roll in and im buying new and used stuff and will be doing all the labor except tune
Old Jan 28, 2014 | 10:42 PM
CALL911's Avatar
Probably recommending it because he is going with a stock bottom end LS1 and talking about wanting to be safe on 10 lbs of boost. "Safe" is a relative term individually defined so I suppose it depends on your definition. To me pump gas and 10#'s of boost on a stock bottom end LS1 = ticking time bomb that will go boom soon. But I usually tend to be on the conservative side.
Originally Posted by transaminator99
i would consider meth if its necessary ... i guess i never took the time to fully understand it i know that the iat sensor controls timing according to temp but stupid question from me is does the meth just spray the iat sensor to give it a different reading or does it actually go into the combustion chamber and cool things down? and i will be running on3's bigger intercooler idk im on a 5k budget when taxes roll in and im buying new and used stuff and will be doing all the labor except tune
Meth cools your IATs and your sensor will be effected by it, but your intake temps will be cooler and your octane raised. These are the two effects that it has that keep you far away from detonation and keeping safe. Computers and sensors can be tricked, so if all the meth did was "trick" you IAT sensor into reading lower, it would be something that could be done simpler than throwing away all that meth.
Old Jan 29, 2014 | 06:30 AM
oscs's Avatar
Originally Posted by CALL911
Probably recommending it because he is going with a stock bottom end LS1 and talking about wanting to be safe on 10 lbs of boost. "Safe" is a relative term individually defined so I suppose it depends on your definition. To me pump gas and 10#'s of boost on a stock bottom end LS1 = ticking time bomb that will go boom soon. But I usually tend to be on the conservative side. Meth cools your IATs and your sensor will be effected by it, but your intake temps will be cooler and your octane raised. These are the two effects that it has that keep you far away from detonation and keeping safe. Computers and sensors can be tricked, so if all the meth did was "trick" you IAT sensor into reading lower, it would be something that could be done simpler than throwing away all that meth.
Relative is correct. I disagree with the need for meth but hey this is the internet.. Everyone can voice their opinion.
Old Jan 29, 2014 | 08:36 AM
LILHEMI's Avatar
whats your reason for not running meth? have you EVER run it?
Old Jan 29, 2014 | 09:49 AM
oscs's Avatar
NO I HAVE NOT see I can type in caps too.. Guess why? Because (again) in MY opinion sub 600hp cars don't need it, ask me how I know.. I love how meth injection is a must have now a days.. You just can't have a safe FI motor without it if it where my money I'd spend it on a GOOD intercooler and a solid tuner.
Again this is my opinion so take it with a grain of salt. I like things to be simple and worry free. Comments made by the OP lead me to believe he feels the same way. I don't like nitrous/meth because you have be bothered with filling bottles and worrying about something failing. Meth works there is no doubt but at the end of the day a damn 550rwhp car setup correctly just doesn't need it.
Old Jan 29, 2014 | 10:06 AM
mrstepheneades's Avatar
I agree that sub 600rwhp cars are fine without meth with a good tune. I was 520ish without meth for a while but when I decided to twist that little **** and pick up nearly 300 more rwhp I put twin nozzles on it and spray the crap out of it. That's why im hitting 21psi on a stock ls1 and its living.
Old Jan 29, 2014 | 10:25 AM
oscs's Avatar
Perfect example.. At the end of the day the OP needs get the turbo on and drive the **** out of it.. If IAT's are out of control which they won't be if he does it right than by all means throw a kit on it. Until then worry about getting it on the road first.
Old Jan 29, 2014 | 10:47 AM
oscs's Avatar
Unrelated question, How long have you been beating on that stock T56? I love hearing stories about them lasting forever at high HP levels..
Old Jan 29, 2014 | 10:48 AM
My iats are fine on street driving. Not been to track but once just on street tires on low boost. I have cheap ebay 4" thick intercooler.
Old Jan 29, 2014 | 10:52 AM
chevellepowered's Avatar
i made 650rwhp on pump gas, no meth , stock th400 and tq convertor, motor 5.3 ly5 , head bolts, mls gaskets, valve springs, ls3 cam , boost was 16-17psi .. Ran good for awhile . motor finally let go , but i think it was my error , couldnt get it to crank one time , messed with the fpr , and prob didnt set it back exactly to same psi .. #7 piston is complety gone ,, next time im goin meth injection ,, ive used it before , and love it .. kits are 250 bucks, next motor is ly6, tune it up to 10psi with no meth , anything beyound 10 psi , im cramming bunch of meth down its throat ..
Old Jan 29, 2014 | 10:55 AM
  #32
Its been 2000 miles nearly at this level. I don't shift hard. Mostly just roll 3rd and 4th gear out for a short few seconds. Not much into hitting 150+ in 4th. Gear calculator says 28" slicks, 3.42 gears will put me at 165 at the top of 4th lol. Its doing fine though. Trans and engine has over 130,000 miles on them. Im pushing water above 6000 at 16psi and 775rwhp so I try to stay below that rpm range since I mostly street drive and always stay at the 21psi mark on the street. LOL We estimate around 900rwhp at that level. Judging how slow it feels at 16psi and 775rwhp compared to 21psi.
I still have factory untouched rear and torque arm too. I know im crazy. Car weighs 3400 on the scales without me (175#) and half tank of fuel and 3 gallons of methanol onboard. That was with the factory wheels and tires. Now full drag setup.
Old Jan 29, 2014 | 10:33 PM
  #33
TurboAv's Avatar
Me personally, I want as much power as I can make per pound of boost. If my IAT's go above 104F my tune is pulling timing. Since without meth my IAT's get in the 180F range at the top of 4th, it makes sense for me to run meth and maximize my timing. Was my tune safe before meth? Yes it was. Am I making more power now? You bet.
Old Jan 29, 2014 | 10:44 PM
  #34
Bottom line is we horsepower nuts are never satisfied. I was satisfied with a goal of 530 rwhp when I started. Same build turned into near 900rwhp and even though im right at grenading engine, trans, rear, etc because all are still stock I still want more. Trust me in the end, you'll always want more. Just get ready, open your wallet, and never close it lol.
Old Jan 29, 2014 | 10:45 PM
  #35
oscs's Avatar
I completely agree with this statement and honestly when my 900rwhp TT build is done I will probably run meth at some point because it will be needed. My argument is at the very basic level which is the simple fact that this guy can easily get away with 550hp without having to bother with a meth injection system. Proper tuning and a quality intercooler can get him there.
What was your rwhp number before meth and after? also how many degrees are you able to obtain while spraying?
Old Jan 29, 2014 | 11:11 PM
  #36
TurboAv's Avatar
I was at 630rwhp without meth and 11* of timing. Added meth and went to 15* of timing and 700rwhp. Bumped timing to 18* and did 754rwhp with E85 and meth. I'm back on 91 octane now and more boost. 13.5psi and I'm only running 10* of timing until my second meth nozzle shows up. Then I will start leaning on it more.
Old Jan 30, 2014 | 06:45 AM
  #37
The Alchemist's Avatar
UNDER PRESSURE MOD
Wow, I see there's lots of anger in here... let's all step back and take a breather for a second....
I firmly believe in the benefits of not only running meth injection, but water/meth injection for a few reasons, especially on a stock motor. First, you need to inject less to have the same positive effects of cooling and detonation resistance. Sure, meth cools the IAT sensor quickly, but the air temperature isn't what is most detrimental to a motor, it's combustion temperatures. The beauty of mixing water in with the meth injection is it doesn't instantly burn off in the combustion cylinder, so it helps pull out more heat than meth does. As the water turns to vapor, it actually raises cylinder pressure as well, and lowers your egt's and helps to pull any carbon deposits out of your entire engine track from intake manifold to the exhaust.
Even at 550hp, I think it's beneficial. Might not be absolutely necessary, but it helps, and let's be honest, how long do we think he's going to stay at 550hp? I give it 2-3 months max before he decides to try some more boost psi.
Old Jan 30, 2014 | 07:13 AM
  #38
CALL911's Avatar
^ agree with Alchemist
Old Jan 30, 2014 | 08:14 AM
  #39
Couple weeks he'll be wanting more lol.
Old Jan 30, 2014 | 02:26 PM
  #40
JetMech99's Avatar
I'm running a bone stock LS1 except for valve springs and an oil pump upgrade, and I made 550 RWHP on a Mustang dyno at just under 7 psi and 93 octane. I have a meth kit on the car, but was having problems getting it to activate, so those numbers are without meth. 550 RWHP is a very easy and safe goal on pump gas! Good luck to ya!
