Frontmount LT1 Question
Old Jan 28, 2014 | 07:09 AM
SwampWS6's Avatar
Default Frontmount LT1 Question
I love starting new threads .
I have a complete turbo kit for my 97 LT1. It is very similar to the Huron Speed kit for the LS motors with truck manifolds. I am asking this before I even get started on the install. Will their be fitment issues with a front mount turbo and the radiator? Is there a special type of radiator I should run? This is really my only concern right now until I start with mocking the rest of the set up together. Thanx for your help!
Old Jan 28, 2014 | 07:18 AM
Shownomercy's Avatar
Man-Crush Warning
Can't say without pictures...
Usually you have to stand up teh radiator vertical which is A) Cutting the radiator support for the stock unit B) Getting a smaller (thicker core) radiator and stashing it under the rad support
My setup does not move radiator from stock location/angle.
Old Jan 28, 2014 | 07:47 AM
SwampWS6's Avatar
Do you have any pics? So your saying that all I have to do is stand the stock radiator straight up?
Old Jan 28, 2014 | 07:50 AM
94LTZ's Avatar
I cut the bottom of the top support out and notched it for the radiator cap, I run a griffin radiator and 2 deral pusher fans. I also run a CSR electric pump and milled the housing down to pull it back toward the block..
Old Jan 28, 2014 | 08:02 AM
Man-Crush Warning
Of my heap?
http://www.ls1lt1.com/forum/moderato...lt1-build.html
Old Jan 28, 2014 | 08:32 AM
SwampWS6's Avatar
DUUUDEEE!!!!!! Your **** is ******* awesome!!!!! WOOOOWWW! The paint on the VC and Turbo is amazing!!! Nice build!!!!!!
Old Jan 28, 2014 | 11:49 AM
Man-Crush Warning
lol, thanks man
Old Jan 28, 2014 | 12:27 PM
SwampWS6's Avatar
I understand without pics you cant really tell, but mine would be mounted like yours, I will run into radiator issues?
Old Jan 28, 2014 | 12:32 PM
Man-Crush Warning
No, I just shifted the bottom of my radiator a tad and it clears the turbo fine.
Old Jan 28, 2014 | 12:34 PM
Gunters96lt1's Avatar
I run a front mount in mine and I just cut the upper support. Running a griffen radiator.
Old Jan 28, 2014 | 12:38 PM
SwampWS6's Avatar
Do I need to run a non stock radiator too?
Old Jan 28, 2014 | 12:41 PM
SwampWS6's Avatar
Attachment 436026
Perfect! That is exactly what I needed to see. Im actually going off your design unless someone can post any better! (doubt it)
Old Jan 28, 2014 | 12:44 PM
I run a griffin cause my stock unit was to tall stood up and I didn't feel like cutting the bottom support as we'll. I'm sure others have done it though....I actually went off of Taburunit's build thread.
I you run an aftermarket rad, you'll have to add a piece for the head vent hose thing. For lack of proper term lol
THADD's Avatar
The stock radiator stood up would be to tall. Get a shorter radiator. Here is my 97 Camaro so you can get an idea
Old Jan 28, 2014 | 12:45 PM
Thadd, your build is awesome!!
Old Jan 28, 2014 | 12:47 PM
THADD's Avatar
Thanks man!
Old Jan 28, 2014 | 01:02 PM
SwampWS6's Avatar
THADD that is a serious piece of work congrats! LOL How much shorter than stock should it be? 3 - 4"???
Old Jan 28, 2014 | 01:51 PM
There's a thread around here just for vertical radiators. I think in this section, lots of good stuff in it.
Old Jan 28, 2014 | 08:26 PM
SwampWS6's Avatar
What are the dimensions of the radiator?
Old Jan 28, 2014 | 10:52 PM
THADD's Avatar
I think my radiator is 26x16
