2# of Boost WTF?
Old May 11, 2004 | 10:42 AM
Ed Blown Vert's Avatar
Default 2# of Boost WTF?
Where are you guys tapping into for the ATI Surge Valve?
I have both the boost gauge and valve tapped into the brake booster. My vendor says I should move it.
Old May 11, 2004 | 11:21 AM
kp's Avatar
kp
you can tap them both in the brake booster line.
what pulley do you have and what RPM are you seeing this at?
Old May 11, 2004 | 11:26 AM
I have the 5# pulley. I see 1.5# - 2# when I first floor it and Stays at 2# all the way to 6300 rpms
Old May 11, 2004 | 11:33 AM
NA$TY-TA's Avatar
How tight do you have the belt??? You are getting built slip or you have lots od mods on your car...... The 5# pulley is for 5#'s on a stock car...... what size in iches is it...... I saw 4 psi with my 4" pulley along time ago........ I tap right into the back of the intake for both my boost gauge, surge valve, and by ref regulator.
Kyle
Old May 11, 2004 | 11:38 AM
That was the first thing I thought belt. I tighten it really tight, could only move it about a 1/4 in. No difference. So I loosened it back up. Didn't want it too tight.
I think the pulley size is 4.10 I'll verify it today when I get home.
I told the vendor my mods and that I wanted 5# of boost.
They think the surge valve is not closing @ WOT. And I should move the line to the TB.
Old May 11, 2004 | 11:52 AM
NA$TY-TA's Avatar
That might be it but that pulley is smaller them what mine came with when i first bought my hit........ I only made 4 psi with a 4" pulley, LT's, no cats, Catback,and a baby 212/218 cam........ You might need to go with a bigger pulley.
Kyle
Old May 11, 2004 | 12:09 PM
SLPSS's Avatar
Yeah that sounds about right. When i got my P1SC #4 installed i had LT headers/loudmouth and from the 4.1# pulley i saw 2# @ 6000 rpms. You should get a smaller pulley or a MMS crank pulley.
Old May 11, 2004 | 12:41 PM
kp's Avatar
kp
A 4.1 on a P1SC will only give you a couple pounds, a 3.4 with a stock motor/headers will give you 6 or 7. If you want 5psi a 3.6 would probably work out.. I wouldnt go any larger then a 3.4 to be honest, you will just end up buying another pulley soon
I run a reichard 3.2, no slip issues at all at 7.5-8.5psi @ 6500.
Old May 11, 2004 | 12:53 PM
Must be my mods that is killing the boost. Grrrr, I told them that I had mods.
I'll check into a 3.4 and 3.2 pulley.
Could I just unplug my vacuumn line to my surge valve for one run to check?? Won't hurt anything will it?
Thanks guys.
Old May 11, 2004 | 01:03 PM
kp's Avatar
kp
if your boost guage works and its hooked to the same place as the surge valve the surge valve is working ok.
I dont think they would have given you a 4.1 pulley, the pulley size will be marked on the parts list that came with the blower..
Altitude has a lot to do with it also, I used to see a little over 8psi with a 3.4 at sea level, here I never seen over 7 with a 3.4 at ~1500'
Old May 11, 2004 | 01:14 PM
They said that the brake booster was still creating vacuumn and that I need to be further away from it. And that the valve was not closing completely. That didn't make sense since I was showing boost. Does it matter which way it is mounted? Instructions say nut on the butterfly points to the J-Tube. Pics show the reverse.
Could I lose any boost through the PCV valve? (I have a check-valve on order)
The parts list show the 4.1 pulley.
I am pretty close to sea level.
Thanks.
Old May 11, 2004 | 01:40 PM
NA$TY-TA's Avatar
Do a T fitting off one of the lines off the back of the intake..........
Old May 11, 2004 | 01:57 PM
Decided to call ATI on the issue. Their records showed I only had H/C's and no Headers. So they sent me the 4.1 pulley. They are now going to send me a 3.7, which should take me to 5#.
Hopefully that will take care of it. Thanks guys and thanks ATI. (Didn't know you guys read this site. Better watch what I say. )
Old May 11, 2004 | 02:14 PM
kp's Avatar
kp
The brake booster line is fine, it has a check valve that closes at boost.
You are losing a little through the pcv, not much though. The crankcase being pressurized is the bad thing.
Glad ATI got you fixed up..
Old May 11, 2004 | 04:53 PM
Thanks again.
Old May 11, 2004 | 06:08 PM
NA$TY-TA's Avatar
Did they charge you for the other pulley??? I hate there...... nothing other then 2 day air crap........ $18 bucks for a crank bolt and washer........... $6 bucks for the parts and 12 for shipping..... It just erks me..
Kyle
Old May 11, 2004 | 06:17 PM
Nope, they didn't charge me. If it works, I just have to send the other one back. But I do have to buy a belt.
Old May 12, 2004 | 10:27 AM
Todd2001SS's Avatar
Tech Addict
I know you will get lots of good opinions, don't be disappointed if it take a few tries to get what you want with boost. It takes time and trial and error.
It soulds like ATI is stepping the pulley one size at a time (from their pulley selection) for you to safely get where you want. The 3.8 probably will not quite get you where you want, don't be up set. I am thinking 3.6 or 3.4 will do it for you. I am leaning toward you needing the 3.4 pulley.
I was running the same boost you are with the 4.1 = 2# (reading the gauge is not easy because of it's size but it was close to this) The 3.4 got me to 5# of boost. These readings were with my stock LS6 intake. When I changed to my Lingenfelter intake my boost went down, (the volume is greater in the intake) then I bought the MMS pulley to bring boost back up.
Remember, you are not experiencing anything out of the norm. Mods always change boost. It will take a little time to get it where you want.
Thanks for the compliments on my engine compartment, show has always been my first goal. Like I said before no I am getting into the tuning aspect.
Good luck!
Old May 12, 2004 | 11:04 AM
I understand that every car is different. But it was obvious they sent the wrong pulley. They are sending me a 3.7 pulley. (Typo from before) Well, if it doesn't get me to 5#. I'll call ATI again.
And I just ordered a 3.2 pulley. Just in case I want more. And we all do.
Which is the best way to go? Smaller blower pulley or larger crank pulley? Time to go search.
Thanks.
Old May 12, 2004 | 11:27 AM
Todd2001SS's Avatar
Tech Addict
Thanks.
If the 3.7 does not work I would consider the MMS Pulley, 3.2 is getting small and may spin. Then if you get the MMS pulley the 4.1 may be perfect, and then you will have 2 good size pulleys and lots of surface area to prevent slipping.
