~NEW Huron Speed V2 Single T4 Turbo Kit *GROUP PURCHASE*
#165
Kit looks great on your car crazy elf !
Today is the LAST DAY!
To be fair to everyone, I will close this when I get to my computer tomorrow morning. Being EST I will not be up until 3am here to be fair to the PST time zone people, so first thing tomorrow morning I will close this down.
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
#172
-4" Downpipe option. Mainly for those wanting to run the mid-frame turbos, we also have a down pipe solution for you as well considering they come with a 4" down pipe discharge opposed to the 3" of a standard T4 turbo. With this, we have developed a 2-piece 4" down pipe that will exit the front bumper on the passenger side. With this, you will still be able to retain the OEM K-member, and your OEM Radiator in the OEM Location!
__________________
#174
Due to the numerous number of different K-members on the market, and how tight of clearance a 4" down pipe fits through them even when build on a car, making one to fit all won't work smoothly. You can however bolt up the 4" bumper style and have a local fab shop use it and route it to the back of the car for you to fit through the K-member you have on the car!
Also, check out the entire thread, we have fit T4 flanged S480's on this kit without having to touch the radiator position and fitting the sway bar, etc! We can get a Billet 84mm Borg Warner with the 96mm turbine wheel in the T4 set-up that will bolt right on this kit!
__________________
#176
With the turbo mentioned above, Billet 84, race cover, 96mm turbine wheel, 1150+ rwhp
__________________
#178
Spool time is dependent on many factors, which makes it hard for me with so many variables. We can get it on a tighter housing to increase spool time. Also your camshaft and other engine factors will play a role in how quickly it will spool. With your cubes, I wouldn't be too overly concerned with spool time however
__________________
#179
Thanks to everyone! GP is now CLOSED. We hit the magic 21 number right on the dot! I will PM and/or e-mail everyone when the final payment is set-up and ready. You will all be able to bundle in a turbo, WG, BOV, Oil Lines, Fuel Injectors, etc etc with your final payment to make the kit as complete as you like and spec'd to meet your performance goals at a nice package discount!
__________________
