Maggie press on pulley quick change option
Old Feb 6, 2014 | 11:40 AM
supersub's Avatar
12 Second Truck Club
Default Maggie press on pulley quick change option
allows you to use existing Maggie 6,8,10 rib pulleys....
Old Feb 6, 2014 | 02:23 PM
punishmentcycle's Avatar
pm sent
Old Feb 6, 2014 | 02:24 PM
hellbents10's Avatar
LS1Tech Sponsor
Awesome!
Old Feb 6, 2014 | 02:46 PM
NitrOmm's Avatar
Will it fit the rear as well ?
If so,
-how much will it add ( space) at the rear. Fbody & MP112 vert tight as it is.
- Do you have a cog set up for the rear
Old Feb 6, 2014 | 05:27 PM
kyoytey1693's Avatar
In for info on the rears too!
Old Feb 9, 2014 | 08:35 PM
mkvamso's Avatar
I'd love to have just one rear to make it 1:1
Much easier to just remove the jackshaft and have one put on instead of removing the blower and .having magnusson do it for way too much
Old Feb 23, 2014 | 01:53 PM
supersub's Avatar
these hubs are designed to use all current 4 bolt pulleys on the older 60,90,112,122 style blowers
Rear can be optioned to run all the current pulley combinations, 8,10, cog, 1 to 1 under or overdrive, and even the LPE 14 rib if you choose..
just wrapping up final fitments and production has already started on the earlier designed shafts.
Old Apr 6, 2014 | 01:56 PM
mkvamso's Avatar
What would a set of cogged rears cost, Magnusson doesn't have the option on m series blowers and I'm pretty tired of fighting belt slip
