Why can't we raise the boost?
Cars that come with turbochargers/superchargers from the factory already have motors built to handle boost. That's why you can generally crank up the boost on the cars you mentioned, without adverse effects. The same is true for the 2003/4 Cobra and the WRX Sti.
For us LS1 owners, we have to spend several thousand dollars to prep the motor to handle high boost, if we want the motor to last. Which is why most people just choose to leave the boost low, and save the motor.
Hope that helps.
Happy racing.
on the ls1 the heads pop off with too much pressure
it sucks, I wish I had gone with a stroker and nitrous now. but am too far into this to change at this point in time.
thanks
ed
firebird455@onebox.com
-Sly
PP Stage 3 LS6 heads (2.055/1.575)
230/236 .592/.578 114lsa +2 cam
1 3/4 LT's with 3in mandrel bent true duals all the way out the back
Ported LS6 intake, Ported TB and MAF, Ported LS6 oil pump
Hardened pushrods, yella terra rockers, asp pulley
Yank SS4000, 3.73 gears
and all the other little stuff to go along with everything, basically every other supporting mod.
Oh ya what size injectors would be required at these levels and will an in tank 255lph fuel pump be sufficient?
...Dang man sorry for hi-jacking the thread figured this will help you out too since you said your learning too
-Sly
P.S. Thanks for all the help guys!!!
), but boost psi is just a number that goes along with CR. PTV cearance and all the others. The idea for power is CFM airflow through the engine. The more through the engine, the more power potential.Cylinder pressure makes power, period! If you have high CR, boost only can raise cylinder pressure so high without grenade results. Each engine is designed for a max cylinder pressure. This involves piston strength, head clamping force, bottom end strength and a lot of other things. Boost motors reduce CR to accommodate extra pressure in the cylinders. A little boost with high CR makes the same hp as a lot of boost with low CR for instance. The ability of the engine to ingest and expel gasses also makes a big difference in the amount of boost psi an engine can live with. A better exhaust with the same setup will REDUCE boost psi, but keep the same or get better hp numbers. Don't ask how much boost, ask how much CFM the combo can process! Just like N/A, think about head flow, exhaust flow and rpm range of the powerband. That'll give you the real answer. HTH
now, about HP of an eclipse. if you were to take let's say a 98 eclipse GSX. and put the normal boltons, upgrade the fuel system, slap on a turbo like a t3/t4 60-1, or even a tad smaller, like a 50 trim. you get some serious numbers, i mean 400 HP is on the low side for that turbo setup.
Part of the reason why they get these numbers is because these ******* push 18 - 25 PSI, with ease. I guess thats how these motors are built to work or something, I don't know. but if these guys were forced to push only like 8 psi or something like that, then ur right, their engine next to a stock ls1 is week.
I hope i didn't rub off as a dsmer....I don't want to get flammed!
not sure how much boost he's pushing, but he's at 1150 crank HP with his 382 all aluminum ls1 (true ls1) with standard arp head studs and grafite gaskets.
-Sly
