torqstorm on a 4th gen 2002 ws6
So how much boost are you running?
Looks like i've got 6# from 4000-4800 but it drops off sharply after that where I think it should continue to climb. I hope the belt is just slipping.
I set the range to 150 on purpose because thats all I needed.
The narrowband histogram shows boost dropping off. 145kpa at 4000. 140 kpa at 4800 and so on.
I would increase the display setting on the map so you can actually see the boost curve. Here's a D1SC car I was tuning that had major belt slip problems.
I had to cut up the underside of my z28 hood to get the Vortech kit to fit. This is a pretty sweet setup and it's cool to see something different.
