torqstorm on a 4th gen 2002 ws6
Old Mar 19, 2014 | 09:21 PM
  #81
ericwilloughby's Avatar
Like a rear o2 sensor? Or what?
Old Mar 19, 2014 | 10:31 PM
  #82
LT1RAY's Avatar
Originally Posted by ericwilloughby
Like a rear o2 se sensor? Or what?
I used the low a/c pressure switch. But this can be using the egr system as well.
A/C low pressure sensor method-
In the scanner, right click on the table display, and click insert. Then under user defined, click configure user defined. Select a open space (mines on slot 4) name it whatever you want, select AFR for sensor and units. Then for the function, insert this pid: " ([PID.7101]/.332)+7.35 ". This is setup for Innovate mtx-l wideband. If its off from the gauge display you'll have to play with the last number in the function. Then connect the 0-5v data logging wire from the wideband and connect it to the red and black wire from the low a/c presure switch. You'll also have to insert "AC Pressure" in the table for the function to actually work. I figured that out the hard way
The egr method is basically the same, the pid will be different and you'll have to find the correct wire to connect the data logging output to.
Old Mar 20, 2014 | 12:19 AM
  #83
Wow. Holy ****.
does pid.7101 tell the ecm to read the voltage coming in on the low pressure ac switch? And the rest math to get the correct # to display?
I use my ac but in a pinch...
My car didnt come with egr but could the input still be there.
I assume I cant use the rear o2 cause its 0-1 volt?
Thats for the pid info. That will be awesome. Would suck to not be able to log my new wb
Old Mar 24, 2014 | 12:58 PM
  #84
Cthulu's Avatar
Thread on HPT's website with some details, lets you log through EGR. I haven't tested.
http://www.hptuners.com/forum/showth...nd-through-EGR
Old Mar 25, 2014 | 06:03 PM
  #85
Default A-pillar gauges in
I can't believe how long this took. 14 hours
Old Mar 28, 2014 | 04:08 AM
  #86
Blackbob's Avatar
Festive !
Old Mar 28, 2014 | 05:19 AM
  #87
I'm Gonna wire the WB up to the ECM so I can log and tune real time today.
Old Mar 28, 2014 | 05:43 AM
  #88
TrickrTreat's Avatar
Very cool . Love seeing people give things a try instead of standing behind a crowd of onlookers shooting it down because it's not what they're comfortable or familiar with.
Old Apr 2, 2014 | 08:23 PM
  #89
Default Which fuel pump?
Here are a few short logs if anyone wants to see them.
I need a fuel pump bad. My pressure tanks <40# up top. Should I do an external Bosch 044 or an intank Walbro 450?
File Type: hpl
File Type: hpl
File Type: hpl
File Type: hpl
File Type: hpl
Old Apr 2, 2014 | 08:37 PM
  #90
Default WB vs NB histograms
Attached Thumbnails torqstorm on a 4th gen 2002 ws6-run-1-wb.jpg   torqstorm on a 4th gen 2002 ws6-run-1-nb.jpg   torqstorm on a 4th gen 2002 ws6-run-2-wb.jpg   torqstorm on a 4th gen 2002 ws6-run-2-nb.jpg
Old Apr 2, 2014 | 08:42 PM
  #91
looks like an .890 is about a 12.5.
and an .870 is about a 13.1
I used to tune for .87-.88 Not bad at all for NB tuning.
Old Apr 2, 2014 | 10:40 PM
  #92
Snake_Skinner's Avatar
Awesome thread, thx for posting and PROPS for trying something different. Subscribed!
Old Apr 3, 2014 | 06:34 AM
  #93
The Alchemist's Avatar
UNDER PRESSURE MOD
I would try to shoot for a little bit richer than 12.4-12.5 with a blower. I would try to get it to mid high 11s honestly.
Be careful.
Old Apr 3, 2014 | 03:33 PM
  #94
Fuel pump?
External Bosch 044? How loud is it?
Internal Walbro 450? How much trouble with the straw or 30r10 hose?
or BAP?
I gotta do something next week.
Old Apr 3, 2014 | 07:15 PM
  #95
SPRAYED 01's Avatar
How about dual walbros in the stock bucket. That will give you room to grow. I used the stock evap line for a return. You can also get 97 98 vette rails that have a return.
Old Apr 3, 2014 | 10:06 PM
  #96
LT1RAY's Avatar
Sweet! Glad you were able to make it work.
Here's a plug and play walbro 430 lph setup:
Wiring harness - http://www.racetronix.biz/itemdesc.a...WH-017&eq=&Tp=
Bulkhead - http://www.racetronix.biz/itemdesc.a...CS-028&eq=&Tp=
Intank harness - http://www.racetronix.biz/itemdesc.a...WH-029&eq=&Tp=
It would be interesting to see how it works on your return fuel setup with the stock regulator.
Old Apr 4, 2014 | 07:13 AM
  #97
I think im going to do that. And while im in there ditch the reg and put one on the fuel rail.
But...its plug n play wiring not install and the contact info for racetronic is total bs. How that hell can one email a www.xxxx/ something
I dont trust them
Old Apr 8, 2014 | 10:28 PM
  #98
Default Walbro f90000262 400lph
I bought this pump and an 8.75" straw and some submersible hose from APE. I got the smaller Walbro turbine pump because I'm going to attemt to use the OEM wiring. It draws 15A and the oem circuit is on a 20A fuse. But I just checked the wiring and it looks like 18 gauge. Damn. If it melts I'll fix it then. Screw it.
Attached Thumbnails torqstorm on a 4th gen 2002 ws6-walbro-f90000262-400lph-.jpg
Old Apr 9, 2014 | 03:30 PM
  #99
Default wiring
Ok, I won't be screwing it, it will be screwing me.
So, I went ahead and next day air the wiring harness kit, tubes, socks...from Racetronix. Thanks Ray.
Attached Thumbnails torqstorm on a 4th gen 2002 ws6-burnt-fuel-pump-wires-1-.jpg
Old Apr 9, 2014 | 07:51 PM
  #100
I did a short thread on the fuel pump trap door here https://ls1tech.com/forums/fueling-i...en-f-body.html
