Stock cam turbo spooling ability
Until then, a quick Google search comes up with results like this. http://www.carcraft.com/techarticles/ctrp_1106_turbo_camshaft_guide/
I'd believe I was well past peak but with the boost I was feeding it didn't seem to nose over or quit pulling hard. By the end I was shifting at 6800 & crossing at 6500
I'm sure a cam spec'd for the combo could have done better, Im just saying I was super impressed with what I was able to accomplish with the "stock LS6 cam."
Until then, a quick Google search comes up with results like this. http://www.carcraft.com/techarticles...amshaft_guide/
also, in my experience, a nice sized cam is better everywhere over the stock cam, but it does not mean you cannot run the same times with the stock cam. all it means is that
1. you will need a few psi more boost to achieve the same result
2. the stock cam is done at 6200 rpms so better have a super effecient converter that will lock up at such low rpms.
What does that have to do with spooling ability? Did you have upgraded springs? I've seen over 700ftlb by 4k and peak power at 5600 on a JY lm7 with springs only.
Not saying a custom aftermarket cam couldn't make more power at higher rpm, or even spool better. Also not saying an LM7 cam is the way to go. In general I would say small duration/overlap cams will spool more quickly on a typical mild turbo setup. IMO most builds tend to over cam the motor.
reading comprehension. it owned you :p
Dont' think so... Never quoted him. Hes talking about a 6.0 cam, not an LM7 cam. My post was directed at you. 5200 seems low. Like I said others have gotten more out of it.
