Turbo LM7 build
For the harness I'm looking at PSI but they're $500 so I may try to modify one myself.
HPTuners will probably be the program used to modify the ecm.
I'm guessing that image is reversed since the alt appears to be on the driver's side. Are those factory truck manifolds (Just looked up your build and see they are SS F body manifolds)? I know it's probably not a big deal for my build but I was going to try to make each side similar lengths before I collect them to go to the turbo. Do you have a picture of that setup from the other side?
The image is not reversed. Fbody alt is on lower driverside. They are 98 Fbody manifolds. (nothing wrong with cast though). Pics are all in my build thread. Pass side is a flipped Fbody manifold 2.5" piping to T4. My merge is not something I suggest you copy. I had limited space and patience when I built this.
