Custom cooling system fittings
Ideally I would use this position. I don't really want to run AN fittings and short of modifying the mounting tabs on thermostat I'm not sure what to do.
And cut you a spacer out.
That matches the new pattern with two sets if holes.
One set matches water pump.
Other set matches new t- housing location.
Just tap that set to threaded bolt you want to use.
