View Poll Results: Which one u prefer?
Voters: 130. You may not vote on this poll
Which one u will chose Procharger vs. Vortech
I would have to agree with Snowboardr18. . Im one for the procharger.. Vortech is a in the way mess.. Procharger setup is clean, and very simple.. Mustang dyno here 543 rwhp on 7.9 pounds of boost.. ( stock bottom end- conservative tune- but can be done!)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
It gets in the way sometimes but I can remove everything but the head unit in about 5 minutes. When you open the hood though it draws a crowd everytime no matter where you are.
It made 690 on a Superflow dyonjet. It made 640 on a Mustang dyno and the tires spun on the rollers so the run was stopped. We took out some timing for a very conservative tune. I am running 15 lbs.
#33
#35
I think all of these old threads being brought back from the dead is a result of the search function listing posts by "relevance" instead of last "post date". I've noticed this happening quite a bit more since the search was re-vamped a while back.
Btw Blown383LS1, what pulley are you running on the T-Trim?
#36
Since the belt issues have been solved with the Prochargers there is hardly a real comparison anymore unless for some reason you want 150-200 less horsepower.
