PCV system with twins?
Old Mar 28, 2014 | 06:18 PM
6togo's Avatar
Default PCV system with twins?
Looking for some input on how to run a pcv system on a twin LSX build i dont have the valley or valve covers yet so i'm flexable just want to do it right so i have no issues!
Pics or diagrams would be very helpful!
Old Mar 28, 2014 | 07:36 PM
ws602's Avatar
-12 bungs in each valve cover to a catch can is what I did.
Old Mar 28, 2014 | 08:42 PM
elkydragger's Avatar
I plan on the same thing. Going to try welded -12 fittings in the valve covers without baffles. I will see how much oil I get in the catch can.
Old Mar 29, 2014 | 09:51 AM
edge04's Avatar
Same. Moroso makes them that screw on, easy install
Old Mar 29, 2014 | 12:12 PM
samdogmx's Avatar
-10s from both valvecovers to vented catch can here.
Old Mar 29, 2014 | 10:00 PM
6togo's Avatar
So no vacuum source from the intake pulling to the catch can?
Old Mar 30, 2014 | 01:47 AM
there is no vacuum in the intake when in boost. The boost will push by the rings therefor pressurizing the crankcase. Hence the reason for the large AN fittings to evacuate the pressure.
Old Mar 30, 2014 | 10:51 AM
6togo's Avatar
so there really is no pcv valve just two vent lines to a can?
I seen some detailed systems that went in and out of catch cans with lines off the compressor side of the turbos and also using vacuum from the intake just a bit confusing!
Old Mar 30, 2014 | 03:00 PM
Street car or race car? You can pull vacuum pre turbo. Depends on what you are using it for. I am drag race only. If you pull vacuum thru a catch can it can't be vented. If you are using boost pressure to "push" into the catch can, the can must be vented. Make sense? No need for Pcv
Old Mar 30, 2014 | 03:45 PM
F110Mech's Avatar
I'll be using the mightymouse PCV catch can to avoid oil fumes and mist in the engine bay. the can goes between the Valve covers and the intake with a one way check valve for when you're in boost. the PCV from my LS6 valley cover will go to a fresh air port in my filter pre turbo.
Old Mar 30, 2014 | 07:59 PM
6togo's Avatar
Street car most of the time!
Old Mar 31, 2014 | 01:38 PM
qqwqeqwrqwqtq's Avatar
On a street car I prefer to not smell any fumes so this is how I set them up.
LS6 valley cover with one way check valve to intake manifold. Both valve covers routed to air filter(s) or induction between air filter(s) and turbo(s)/supercharger.
Old Mar 31, 2014 | 02:05 PM
6togo's Avatar
Yes i definitely don't want smell or most everywhere! I will probably be using a single plane intake and a flat billet valley cover so I don't think the ls6 cover is in the cards.
Old Mar 31, 2014 | 06:11 PM
oange ss's Avatar
Try this; part numbers for the check valves are floating around here somewhere, they are GM pieces.
Old Mar 31, 2014 | 09:13 PM
rkreigh's Avatar
vented valve covers stink sorry, but I'm looking to either move the catch can to the back of the car or go with an RX dual valve catch can designed for boost
I'm worried that the little 3/8 hoses aren't near big enough
the -10 I have now have a larger inner diameter and flow alot more
I also think my engine has some excessive blow by so I'm checking out the leak down and compression
its a ttix car with about 20k on the build
Old Apr 1, 2014 | 07:17 AM
6togo's Avatar
I read allot of guys pulling vents from the valley pan instead of the valve covers is that a better route say two lines from the valley to a catch can they send them bach pre-turbo might require two cans and have them check valved?
Old Apr 1, 2014 | 08:15 AM
runsfromdacops's Avatar
I'm running -10 from both valve covers to a large baffled catch can.
If u baffle the catch can correctly you will have no oil vapor at all
