346LS1 block vs. 370 Iron block...
-Sly
depending on how you'll boost the engine, i would go with the iron block for a turbo and an aluminum block if supercharging using an ati kit. the reasoning is that i't easier to cool the iron block with the stock fans, where as the aluminum block is easier to cool with aftermarket fans( ati kits get rid of the stock fans and replace it with a crappy single)
plus its lighter.
beyond 20 lbs of boost i'd go with iron block cause they offer more strength.
Kyle
however it'll be a little while before I run that much boost, I still need to upgrade the fuel system and build the meth injection kit. GotMeSome- I've allready set up to have the block oringed and have the arp head studs on their way as well.
Thanks for the input guys.
-Sly
Thats why I just stuck with aluminum.
If that doesn't work out, I'll probably go with a setup like Kyles.
Rob
I take it you talked to the Boys at AP Engineering......... Great guys to deal with and great customer service.
Kyle
-Sly
Kyle
