prepping a 5.3 for boost
Old 04-16-2014, 10:46 PM
nofxgivn's Avatar
you can get the gm part # 125955365 for about $8 each 4 required from the dealership.if you decide to buy a new cam you can get new gm lifters part #12499225.the delphi ones are $99 and gm are $140.both have same part number.if the dealer ship is more then i am saying the you can also use liljohn or brian tooley.hope this helps some
Old 04-17-2014, 07:50 PM
LILHEMI's Avatar
Originally Posted by 2muchboostNY
Google "5.3 notch" and the first image that comes up shows the 5.3 heads with and without the notch. I did not want to post the link for Performance Truck as I am not sure if that is against the rules.
The LS1 or LS9 gasket will only work if you do not have the notch which requires a Graphite HG vs a Metal MLS like the LS9.
this is bullshit. victor reinz makes MLS gaskets for the notched heads.
Amazon.com: Victor Reinz 54441 Cylinder Head Gasket: Automotive Amazon.com: Victor Reinz 54441 Cylinder Head Gasket: Automotive
this is why people spend ludicrous amounts of money on their cars when they dont have to. internet misinformation.
Old 04-17-2014, 09:13 PM
2muchboostNY's Avatar
^^^hence why sent him to the post and also said "correct me if I am wrong". From what was gathered it stated that the VR hg would work on both notch and non - notch heads but the LS specific hg like the LS9 will only work for non-notch.
Old 04-18-2014, 11:36 PM
Black98s10's Avatar
If your motor comes with the Castech 706 heads, I'd probably swap them out right away. They have a habit of cracking. Google castech 706 heads, it should pull up some articles, and show you how to I.D. them. I just wish someone would've told me about them before I stuck money, into mine.
Old 04-20-2014, 08:26 PM
soccerdave's Avatar
square port l92 823 heads are the ticket, the ls9 head gaskets will keep them sealed
Old 04-20-2014, 08:57 PM
91FormulaKiller's Avatar
Can't run square port heads on a 4.8/5.3, they're designed for 4.00" bores and I believe there's PTV issues.
Old 04-21-2014, 04:46 PM
willizm's Avatar
any recommendation on budget pushrods that are durable?
Old 04-22-2014, 09:55 AM
STEEPSS's Avatar
Originally Posted by LILHEMI
this is bullshit. victor reinz makes MLS gaskets for the notched heads. Amazon.com: Victor Reinz 54441 Cylinder Head Gasket: Automotive this is why people spend ludicrous amounts of money on their cars when they dont have to. internet misinformation.
How is it bullshit that the ls1/9 gaskets don't work on notch heads?
They do leak - I've seen it myself
However, I'd agree that link is a good alternative.
Old 04-22-2014, 10:41 AM
LILHEMI's Avatar
He said the notch REQUIRES graphite gaskets. Thus the response.
Old 04-23-2014, 03:52 PM
chevyrules85's Avatar
question on the trays, what are the differences between ls1s, 5.3s, ls2s? I saw them listed on brian tooleys site, but it says for ls2 and newer. would they work for my 03 5.3?
Old 04-23-2014, 08:28 PM
nofxgivn's Avatar
as far as i know you can use the ls2 tray in your 5.3.the part# on the trays for your engine should be 12595365 if i remember right.they should be about 7.95 each.hope this helps
Old 04-23-2014, 08:58 PM
  #32
thanks man! is there any advantage to ls2 trays? anything better about them? material?
Old 04-25-2014, 09:13 PM
  #33
Anyone about the trays? and what's a good alternative for a performance timing chain and gears? thanks again for all the info guys!
Old 04-28-2014, 09:25 PM
  #34
superstreeter's Avatar
Build a 6.0 and run 14 # of boost, that shud get you around 600 hp and maybe a cam change to go with it. A 6.0 seems to make way more power than a 5.3. Im not sure why, because the cube diff aint that much !!!
Old 04-28-2014, 09:37 PM
  #35
LILHEMI's Avatar
If this is true the answer is simple.
Old 04-28-2014, 10:24 PM
  #36
nasty64's Avatar
Good info as im in the planning stages of my 4.8 turbo build in my 64 belair. Working on finishing the floors then the body goes back on the finished chassis. Then motor/trans, fuel system ect....
Old 04-29-2014, 11:16 AM
  #37
OUTLAWZ RACING's Avatar
We did a 5.3 with the following parts:
04 ls6 cam
prc 650 springs. I know lol
ls9 head gaskets
ARP Head studs
open the ring gap I don't recall how much.
ARP rod bolts
ls2 lifter trays and lifters
ls2 oil pump with red spring
iwis timing chain
ls6 intake
BW s480
317 heads stock valves no portwork
80# injector duty cycle 78% with meth on the safe side
13* timing AFR average 11.3-11.6
This combo netted us 700+ on 17_18 psi through a 4l80e with a nitrous converter. We will swap the converter at a later date.
Old 04-29-2014, 11:19 AM
  #38
^^With that setup what is does the powerband look like and where does it peak at?
Old 04-29-2014, 11:37 AM
  #39
LILHEMI's Avatar
04 ls6 cam
ls9 head gaskets
ARP Head studs
ARP rod bolts
iwis timing chain
ls6 intake
BW s480
jeez man i made 800 to the wheels on 18 psi and 11* timing with a bone stock 5.3 with mls gaskets and chinese head studs on an S480 through a th400.
Old 04-29-2014, 09:01 PM
  #40
Peak power was at 63k rpm peak tq was at 52k rpm
The difference here is the 317 heads the 5.3 came in short block form and he had already purchase 317 so we ran with them.. The compression on a 5.3 dish pistons is around 9.5.1 or 9.7 cant remember off the top. Ill have to look at the build notes on it but the compression is low. Later on we are going to machine a ring in the head and block for the mile event this year and set it on kill
Quick Reply: prepping a 5.3 for boost
