mercury capri 1999 4.8/80mm/microsquirt/th400/640whp
Well popped the engine knew the old 99 motor was living on borrowed time when it did 600+ hp Owell just picked up a 05 5.3 some new China studs and a cam from liljohnsmotorsports can't wait to see the new results and to rip into the old engine to see the cause
Matt I knew it would happen sooner than later. I usually pressure test stuff and find weak points aka I beat on them. So what do you think the cam med 05 5.3 will hold together at?
