Engine Management Suggestions- LS3 with Maggie
Old Apr 17, 2014 | 10:28 PM
Jdseeling's Avatar
Default Engine Management Suggestions- LS3 with Maggie
I want some suggestions on an engine management system for my fully built LS3 with a Maggie 122. I will be running 16 pounds of boost. This motor came with a 68 Camaro I just bought. Car is a full pro-touring build and is more than setup for this motor. Let me know.
Old Apr 17, 2014 | 11:55 PM
LLLosingit's Avatar
There are several that will do the job, I'm going to use the Holley Dominator EFI for my 6-71 blown 408 because it will also control the 4l80e trans I will be using. Holley also has their HP system, It basically a stripped down version of the Dominator system for those who don't need to control the trans and a few other features found on the Dominator system.
There is also "Fast EFI" and "Big Stuff 3" among others.
Old Apr 18, 2014 | 12:01 AM
Jdseeling's Avatar
My car a T56 setup so no need for transmission control. I have looked into Fast but not Big Stuff, I will. Just want something reliable or at least as reliable as I will get with a motor like this! Thanks for your input.
Old Apr 18, 2014 | 05:32 AM
JAX04's Avatar
You can't go wrong with any of the big names.
Do a search, this has been beat to death around here lately.
Old Apr 18, 2014 | 06:30 AM
Jdseeling's Avatar
Yeah, I have done a couple of searches and will do a few more. Thanks for your input. Thanks
Old Apr 18, 2014 | 10:46 AM
denmah's Avatar
Moderator
microsquirt could also do it on quite a budget
Old Apr 18, 2014 | 05:10 PM
stevieturbo's Avatar
Do you need or want any features other than very basic engine control ?
if you're racing, datalogging ?
Old Apr 19, 2014 | 06:57 AM
forcd ind's Avatar
I used the Holley HP, with the right wiring harness it was simple to install, and easy to get running-I always ran blowthru carbs, so my first FI
my computer skills are pretty lacking, lol, so some stuff I didn't understand, but so much info out there it was easy to get help
they have a great data logging ability, and have an internal logger if you don't have the laptop hooked up
I run around 14 lbs boost, punch in some #'s, and it learns and makes the adjustments
Old Apr 19, 2014 | 09:42 AM
rkreigh's Avatar
does the micro squirt have a tranny control yet?
these things look awesome and are very affordable
Old Apr 21, 2014 | 06:53 AM
soccerdave's Avatar
anymore having a controller that can handle all components is a plus so you can fine tune the entire setup...
