Help not sure what to do vortech ysi
Get a bigger blower. If you want more low end torque put a restictor plate in. I run a stock LS6 with a small blower and get 588RWTQ with a restrictor plate running 10 psi.
Well my builder/dad has done a ton 383 and he done them at 530-540 hp and 600ftq and that's na so if I get that and then my current blower I should be around 750-800ftq and 725-750hp and that will make me happy cuz that's a good range for hooking the tires to the street and it will still be nice to drive
I'd just go with the bigger blower.
Look brother, you're fighting a losing battle against both physics and thermodynamics and possibly a few other branches of study. Nobody is saying you can't strap a G trim to an LS1 and spin it fast enough to make 600 rwhp but you are literally at the limit of how much air that blower will move with any semblance of efficiency. Moving to a 383 may get you a little more low end torque but you're not going to make much, if any, more power than you are now because that head unit just isn't built to move that much air without heating it beyond reason.
It's just as easy to make 800 rwhp with a 347 as it is with a 383 but you need the right parts to do it. Either a heavy duty T trim or a YSi is what you need, not a stroker kit.
If you decide to go with a T or YSi you can't use your current bracket. You'll have to get a whole new bracket setup from an aftermarket company who won't be responsive to your needs. Trust me, I know from experience and others on here have too. If you want to go to a bigger blower, sell what you have now and switch to a Procharger F series.
#39
I agree buddy problem is 1. all advice is individuals opinions so you have to weigh them against each other and 2. the other problem is people do not listen when they get a majority of people trying to help them with the same opinion.
