Ton of Boost with stock heads... who does it?
My car is pretty light and i am considering running x275 with a billet 80mm at 2800lbs and was not sure if my motor combo will be able to handle a billet 80 with the gate pinned shut. i suppose it will make around 30psi on kill.
stock block
ls9 gasket
ARP 625 aged studs (got em for extra 150 from engine builder!)
LSA Heads 9.7:1 Compression
c16/q16
And the LSA heads are think are your friend, they are a heavier casting then say a 317...
Boost the **** out of it. Remember... Torque is what lifts heads... besides bad tunes.
I believe Martin was planning to run his LSA heads in RS, and i think them guys pin the gate shut...
im sure most guys dont really pin the gate, you get to a point where the turbo will make another psi and not gain any power but create higher IAT's
got ya, when he said "pinned shut" I took that literally.
