Derale Fan Alternative
Old May 20, 2014 | 04:18 PM
98Camarod's Avatar
Originally Posted by 1999Black_Z28
I wonder if Derale is fixing their wiring issues and that's why everyone is out of these. The fans seem to work good but the provided harness leaves a lot to be desired (google search told me this is a common issue). When one of my fans cut out on me, this is what I found. The 30amp fuse didn't blow b/c it was oversized for the wire gauge causing the wires to get hot enough to melt.
I since had to buy an aftermarket fan harness rated to handle the amp draw of the system...
Attachment 451724
Same thing happened to me
Old May 20, 2014 | 10:23 PM
Bimmerdude's Avatar
Originally Posted by fly boy_1
I think one of those was installed on a Jeep I helped rewire. They worked ok but I'm not sure they are on par with some of the better derale fans.
Anyone used the spal fans with their big motor like this:
http://www.summitracing.com/parts/sp...3202/overview/
Some thinner options are out there:
http://www.summitracing.com/parts/sp...2802/overview/
CFM's drop in kind though. The derale fans seem to be special and not a lot of other options with true high power motors.
I think I might give the spals a shot and just make my own shroud, but time will tell.
Old Aug 5, 2015 | 09:54 PM
Rockrz's Avatar
Spal fans are the better bet... they make many of the OE fans used by vehicle manufacturers.
Old Aug 6, 2015 | 02:15 PM
VTC_WS6's Avatar
I've had success also with the Derale pushers on my turbo TA even in our brutal S. Fla heat, temps never become an issue however the ridiculous voltage drop is something I'd like to minimize.
Old Aug 6, 2015 | 02:23 PM
Rockrz's Avatar
Here ya go... http://www.autocoolguy.com
Pullers would work better. All OE fans used by vehicle manufacturers are puller fans so their research must show that pullers work better than pushers.
Old Aug 6, 2015 | 02:28 PM
necrocannibal's Avatar
I'm running Derale pushers and they keep my car cool, even when the heat index is over 110 which happens a lot in the summer. I do have the voltage drop but I'm hoping to buy an agm battery that's at least 60 or 70 amp hours and see if it helps.
