Derale Fan Alternative
Old May 14, 2014 | 09:06 AM
Shownomercy's Avatar
Man-Crush Warning
Default Derale Fan Alternative
So, I had a 16925 fan die on me, summit warrantied it, but, go figure.. their back ordered to end of June tentatively.
I cannot find a direct replacement at that size with the flow rate, any ideas?
Old May 14, 2014 | 01:56 PM
crazyelf's Avatar
I gave up on waiting for the derale fans after a few months of waiting. I ended up moving the lower radiator support and notching the upper to move the radiator down and forward.
Gave enough room to use stock fans.
Old May 14, 2014 | 03:22 PM
necrocannibal's Avatar
What size are they and are they pushers or pullers? I have a set of Spal fans I am not using that might work for you.
Old May 14, 2014 | 07:55 PM
Man-Crush Warning
12x12 pushers
Old May 14, 2014 | 08:02 PM
12x12 pushers
What I have are pullers but they move 3000 cfm of air a piece. May or may not work as pushers. It's weird they are on back order so long I got to derale pushers pretty quickly a couple of months ago.
Old May 14, 2014 | 09:01 PM
93camaro_zzz's Avatar
Just curious, why do you have to go with Derale? There are easily another 15 different fan manufacturers covering a full spectrum of sizes and price ranges.
Old May 14, 2014 | 09:56 PM
caMnaro's Avatar
Its very hard to find a pusher that flows 2000+ cfm at 12"x12". I am in the same boat as i need two to finish my cooling system
Old May 15, 2014 | 10:57 AM
For example:
Perma-Cool Standard Electric Fans 12 inch 2300cfm
And it is reversable, so it can be push or pull.
Old May 15, 2014 | 11:45 AM
caMnaro's Avatar
For example:
Have you used this fan by chance? It seems from the rating they flow a lot of cfm, but each manufacture has there own scale. If you research the part number online for reviews, they don't have to many good ones. A guy switched to these from his 1400 cfm fans and they did worse. Again if your using them and they work maybe i will try them.
Post #4
http://www.nastyz28.com/forum/showthread.php?t=266499
Old May 15, 2014 | 03:06 PM
GoodSpeed150's Avatar
I have 2 derale fans. I've been running on only one for a while now. As long as you don't turn the a/c on it should keep the car cool.
Old May 15, 2014 | 04:15 PM
98Camarod's Avatar
As pushers I definitely need both of them to keep it cool.
OP I'd try ebay and get one off of there.
Old May 15, 2014 | 07:29 PM
transam69230's Avatar
etrailer.com had some. I bought a derale fan from them back in March.
Old May 15, 2014 | 08:01 PM
Man-Crush Warning
Negative, called em, and they have back ordered them as well.
Just waiting now, hopefully a couple more weeks.
Old May 15, 2014 | 10:13 PM
F110Mech's Avatar
Mine are on order from etrailer and should ship next week
Old May 16, 2014 | 06:18 AM
1999Black_Z28's Avatar
I wonder if Derale is fixing their wiring issues and that's why everyone is out of these. The fans seem to work good but the provided harness leaves a lot to be desired (google search told me this is a common issue). When one of my fans cut out on me, this is what I found. The 30amp fuse didn't blow b/c it was oversized for the wire gauge causing the wires to get hot enough to melt.
I since had to buy an aftermarket fan harness rated to handle the amp draw of the system...
Old May 16, 2014 | 07:12 AM
Man-Crush Warning
I hope they do for you, but I would call and confirm that date. Summit originally said the 19th for me as well and that slipped out to June.
I run a leash relay board so I do not use the relay stuff that comes with the fans.
Old May 16, 2014 | 09:39 AM
F110Mech's Avatar
I've been in contact with them but I wont be home from over seas until august so I'm not worried
Old May 16, 2014 | 10:37 AM
caMnaro's Avatar
Well i have had two on order with Jegs since 1/08/14, hopefully they get released soon or i might try out some other pusher setup.
Old May 16, 2014 | 10:47 AM
boostedsl2's Avatar
I would wait it out and/or get a cheap replacement to get you by.
I have two derale 12" pullers. they are bad ***. Best fans i've ever used. The perma cool metal blade open fans are good, but I don't think they would hang with these. Not to mention the derale's are cheap. I think the twin set with shroud is under $220 shipped. Edit: I guess they went up in price. They are listed at $247.99
the downfall is that they draw 265 watts each (~25amps). I added a 5 farrad cap to help the voltage draw when they spin up. the cap brought the 3 volt drop down to about 1. A factory controller with softstart would help out quite a bit.
The harness that comes with it is pretty much garbage. The wiring has held up, but the relays were bad out of the box. the wiring harness is on my list of things to fix.
I'm running them on a stock rad in a single turbo silverado in FL. I don't have my AC hooked up, but they will take the coolant temp from 195 to 175 in about 45 seconds once fully warmed up in 80+ degree weather. I have a condenser, 11x11x1.5 trans cooler and a 3" intercooler in front of it. When they are on, you can feel the air being pulled through the intercooler up front.
Here they are...
http://derale.com/products/electric-...fitting-detail
http://www.jegs.com/i/Derale/259/16928/10002/-1
Old May 20, 2014 | 11:32 AM
fly boy_1's Avatar
Has anybody used one of these? http://www.summitracing.com/parts/mar-mjs26k/overview/
