3rd vs 4th Gen Rods
Old May 22, 2014 | 03:56 PM
thendawg's Avatar
Default 3rd vs 4th Gen Rods
How much stronger are the newer, 4th gen rods found in the 05+ motors? I was originally looking for 05+ 5.3's however Ive found a couple good deals on some 01-02 motors. Would these shortblocks still hold up at 700whp on E85?
Old May 22, 2014 | 04:51 PM
stock48's Avatar
9 Second Truck Club
At least 200 hp worth. I bent the early rods running mid low 10's in my truck, and have been 9.7 and even quicker in the 1/8 with the 06 engine.
Old May 22, 2014 | 05:28 PM
thendawg's Avatar
Thanks! Thats kinda what I was thinking. I really want an L33, but damn, the prices on them have gone up so much. Cant seem to find one under $1000.
Old May 22, 2014 | 06:10 PM
stock48's Avatar
9 Second Truck Club
The early engines will still handle around 800 hp with a soft tune. Past that Id look for the better rods.
Old May 23, 2014 | 12:39 AM
CameronVic's Avatar
Just get a newer iron one with gen 4 stuff, L33's are all hype (I do wish I had one though, lol). I've trapped 112.9 in the 8th at 3900lbs with the older gen 3 rods and 862 heads. I just sold that motor and put a gen4 5.3 together with milled 799 heads and a cam from this^^^ guy. It should hustle pretty good when I eventually have time to work on my own junk!
Old May 23, 2014 | 06:23 AM
JoeNova's Avatar
Restricted User
Seeing as the L33 is the only engine with stock rods/pistons so far to run a 4 second pass in the 1/8th mile, I wouldn't really call it hype. Skinnies ran the first 8 second quarter mile stock bottom end pass with an L33 if I remember right. There must be some magic joo joo in them.
Old May 23, 2014 | 08:22 AM
forcd ind's Avatar
is it hard to tell the early rods from the later-I have an LQ4? that sup came out of an 05 Denali, but had dished pistons-thought they would be flat
Old May 23, 2014 | 09:52 AM
turboventura's Avatar
The lq9 had the higher compression flat tops, you could still have the better rods/floating wrist pins
Old May 23, 2014 | 11:14 AM
9sectruck's Avatar
I just bent all 8 rods in a 07 ls2 engine at 19psi roughly making 900rwhp. all but 3 rods came out the bottom of the engine
Old May 23, 2014 | 11:20 AM
JoeNova's Avatar
Restricted User
Type the topic of this thread into Google. There is a few side by side comparisons out there. The 4th gen rods are much much beefier than the 3rd gen.
Old May 23, 2014 | 11:22 AM
JoeNova's Avatar
Restricted User
I see this from time to time. I've heard of 3 LS2 engines breaking rods below 1000 HP. At the same time I've seen 3 different engines hit 1300 HP on gen 4 rods over and over and over and repeatedly beat on them without failures. It could've been heat related or excess low-end torque that did yours in.
Old May 23, 2014 | 12:13 PM
CameronVic's Avatar
I have an iron 5.3 with 799s and dished pistons. Only difference between my motor and an L33 is .5 compression and 75lbs. Slap that mug in a 3000lb car and it's going 8s. And they are all hype, that's why they're 4 times the cost of what I pick up my iron 5.3s for and I can pretty much do the same thing with mine.
Old May 23, 2014 | 12:17 PM
CameronVic's Avatar
Gen 3 near, gen 4 far.
Gen 4 left, gen 3 right
My gen 4 rods have pressed pin pistons and are dished.
Old May 23, 2014 | 12:21 PM
thendawg's Avatar
Yeah i find it funny the Gen4 rods look ALOT like some of the cheaper aftermarket rods (Scat I beam in particular)
Old May 23, 2014 | 12:23 PM
thendawg's Avatar
Main reason I wanted the L33 is the better 243/799 heads. Im not TOO concerned with weight, but being a GTO, ever little bit does help. I know I could just find some heads for the LM7, but a newer LM7 (05+) is only about $300-400 cheaper than the L33, at least here in the OK/TX area, so I almost feel itd be worth it to just go L33. Also LKQ has a couple <100k L33's and theyre good about trading the motor out if I tear it down and find its damaged.
Old May 23, 2014 | 12:50 PM
Photochop's Avatar
What did LKQ want for a <100k L33? Wonder if they'd give us a deal if we bought 2 at the same time
Old May 23, 2014 | 01:09 PM
thendawg's Avatar
$1130 I believe. I talked the guy into waiving the core charge for me, and it would be delivered to the place on Reno for free. Also said if I bring in my tax ID theyd waive the tax so itd basically be $1130 out the door.
Old May 23, 2014 | 01:12 PM
caMnaro's Avatar
Here is a picture next to a Crower I beam.
Old May 23, 2014 | 01:19 PM
thendawg's Avatar
Obviously the difference is in material strength (4340 forged, vs powdered) but Im really curious to know how close they are strength wise.
Old May 23, 2014 | 01:34 PM
JoeNova's Avatar
Restricted User
Ask Brian Tooley about a certain Camaro that ran an entire season at ~1400 HP on gen 4 rods.
