On3 performance 78/76
Old Jul 23, 2014 | 02:00 PM
  #141
FrossB's Avatar
When were you seeing your full boost? That's a decent update! Especially since im going back and forth with the GT45 and this turbo
  #142
Forcefed86's Avatar
Originally Posted by viper6549
I was at the track last Friday night but was battling serious problems so take results with a grain of salt. Turbo starts making boost a lot sooner then the GT45 did, I was able to build 5psi on the foot brake as where the GT45 I was lucky to get 1psi. I ended up letting out an both runs at about the 1000ft'ish mark and ran 11.8 101mph with a 1.9 60ft and 11.7 with a 2.0 60ft don't remember the last mph. I only made two run before I lost oil pressure due to rod bearing. Not the best update, I guess better then nothing though.
This was a 3600lb tank with a 5.3 with 862 heads and a tu1.5 cam runnign 14PSI boost
1/8th mile comparison times?
Old Jul 23, 2014 | 02:13 PM
  #143
viper6549's Avatar
I will have too look at the log to see when full boost was coming in, or better yet I will post the log this evening.
Exact same 1/8 as the GT45, 7.5 at 96mph. I will post time slips along with log if I can find them.
Old Jul 23, 2014 | 02:16 PM
  #144
FrossB's Avatar
Sweet thanks man!
Old Jul 23, 2014 | 04:17 PM
  #145
baggedsvt's Avatar
Old Jul 23, 2014 | 08:26 PM
  #146
viper6549's Avatar
Seeing full boost around 5100 9psi around 4000.
Old Jul 23, 2014 | 08:36 PM
  #147
Rise of the Phoenix's Avatar
Originally Posted by baggedsvt
That's one of the best t-shirts I've seen in a while.
Old Jul 23, 2014 | 09:49 PM
  #148
FrossB's Avatar
Maybe I'm wrong but that seems a little late? What size hotside piping and cam are you running?
Old Jul 24, 2014 | 08:24 AM
  #149
viper6549's Avatar
2.5 hot side. The cam is completely wrong, it's a TU1.5 so I would take my results with a grain of salt.
Old Jul 24, 2014 | 08:28 AM
  #150
FrossB's Avatar
Ahh that makes more sense. I'm running 2.25 hotside and a stock (for now) 5.3 cam so I should have a little better spool.
Old Jul 28, 2014 | 01:53 PM
  #151
denmah's Avatar
Moderator
well an update here for you guys
On3 performance 78/76-nnxivyr.jpg
the billet 76/96 on 14psi made 515whp, just like the 76/65 and the 78/75
so there is no power figures with the 78/75 like we wanted but i did find out that something else is wrong with this setup, going to swap the cam next with a LS2 cam since they are not great but they are not terrible, it will let me know if the cam is the problem or if i have to start going thru the driveline
Old Jul 28, 2014 | 05:05 PM
  #152
1969x11's Avatar
Sucks you've got underlying issues, but looks like the 78/75 maybe a winner after all. Will you be able to test it again after you find the problem? You would think a 216/220 on 114 would be a decent turbo cam?? Thanks for the hard work Denmah.
Old Jul 28, 2014 | 05:17 PM
  #153
Sarg's Avatar
Surprised you are not using a Circle D converter on this one. That at least would eliminate blowing through the converter.
Old Jul 29, 2014 | 10:46 AM
  #154
denmah's Avatar
Moderator
feels like its pulling fine, i hit high mph easily, i have had other cars iwth 40% converter loss and you sure can feel it.
also, i pulled the cam out of this truck last night in my spare time after tuning an off road buggy, and it made only 15hp less...
something is crazy wrong here hahah
Old Jul 29, 2014 | 11:11 PM
  #155
Slow6speed's Avatar
Id really like to know whats going on. Im looking at buying one asap.
Old Jul 30, 2014 | 06:58 AM
  #156
Forcefed86's Avatar
You all need to degree that joker and see where it's at. My 08 5.3 motor was def 6* retarded dot to dot. Threw the same cam in my 06 4.8 and it was almost dead on dot to dot. (same timing set and chain as well) The "new" cam you threw in may be way retarded as well.
Old Jul 30, 2014 | 07:15 AM
  #157
viper6549's Avatar
I have a fresh JY motor in the thirdgen and the car feels like a different animal. I will have some track time Friday so I should have a solid update.
Old Jul 30, 2014 | 06:44 PM
  #158
Dzel's Avatar
I'm running 230/236 114. When I was going to order my boost friendly cam from Texas speed they suggested 230/236 112. They stated that my can wool work perfectly fine with the setup I have. But would be more better with the 112lsa
Old Jul 30, 2014 | 08:47 PM
  #159
JustAFooL's Avatar
Old Jul 30, 2014 | 09:17 PM
  #160
justinkp's Avatar
I don't know what's wrong with these guys thinking that a turbo cam on a 112lsa is a good thing. That's horrible. Maybe Mr Martin Smallwood could chime in on that.
