On3 performance 78/76
Old Jul 3, 2014 | 09:21 PM
  #101
I8URLS1's Avatar
Yeah I hope these are a result of something else or it's not going to cut it for my twin setup at all
Old Jul 3, 2014 | 09:28 PM
  #102
denmah's Avatar
Moderator
i want to see some other results honestly but at least in this setup it was not worth the swap, we just did it because my friend who bought the 78/75 is a little bit out before he can install it, so he let me borrow it.
this is the same hotside that was on my 6.0 2500 truck that did 675whp on 16psi with a magnum 80mm
so i figure the hotside can at least do 600+ so i dont think that is holding it back.
Old Jul 3, 2014 | 09:43 PM
  #103
viper6549's Avatar
Well that's not exactly what I wanted to hear.
Old Jul 3, 2014 | 09:44 PM
  #104
Photochop's Avatar
That's pretty low power for a 6.0 @ 20psi with either turbo. Big power eating converter/rear/tires on that truck?
Old Jul 3, 2014 | 09:49 PM
  #105
denmah's Avatar
Moderator
stock converter, 80e, 30s street tires
Old Jul 3, 2014 | 09:58 PM
  #106
Rise of the Phoenix's Avatar
Not what a lot of us where hoping for. I'd like to see some others results befoe I make a judgement.
Old Jul 4, 2014 | 08:52 AM
  #107
1969x11's Avatar
Lots of jerking for a dismal climax...I was hoping to see about 650whp on 15psi. Are you sure it has a 76mm exhaust wheel? Thanks again for the comparison Denmah!!
Old Jul 4, 2014 | 09:12 AM
  #108
Sarg's Avatar
Blowing through the converter maybe?
Old Jul 4, 2014 | 09:21 AM
  #109
I8URLS1's Avatar
I would like to see dyno #s with a manual just to see what it's capable of before writing it off
Old Jul 4, 2014 | 09:42 AM
  #110
Ron_Stoppable's Avatar
Damn wow! I wanted to make at least 600-650 with it!
Old Jul 4, 2014 | 11:58 AM
  #111
Sarg's Avatar
I really feel there must be something else at work here if a 5.7 can make over 700 with the 76. Either that or this is just a horribly designed turbo.
Old Jul 4, 2014 | 02:53 PM
  #112
Cstone812's Avatar
Was gonna purchase one for my huron speed kit. Kinda want to see some more results.
Old Jul 4, 2014 | 04:23 PM
  #113
denmah's Avatar
Moderator
IMO the smaller motors make great power with the china turbos, because of the small turbine.
i dont know how the hell anyone does 700+ with the 76mm honestly lol
Old Jul 4, 2014 | 06:53 PM
  #114
sbcgenII's Avatar
Waiting for more dynos or some track results.
Old Jul 6, 2014 | 06:22 PM
  #115
fly boy_1's Avatar
Id imagine you might need a different cam profile for the larger turbine wheel, or spin more rpm vs more boost. Isnt the point of the larger wheel to carry the power higher vs quicker spool/lower peak power? If its a copied turbonetics wheel design it should do better than mid 500s.
Old Jul 6, 2014 | 10:20 PM
  #116
denmah's Avatar
Moderator
i have a billet etr ho 76mm coming and im swapping that on, if it doesnt make big power i am doing a cam swap to see if i got the wrong cam this time
Old Jul 7, 2014 | 11:11 AM
  #117
norotor7's Avatar
swapped it on a 500whp on3 equipped built 6.0 truck and it makes nearly the same power as the 76 at the same boost levels, just makes slightly more hp
honestly not sure whats up with that, might be something else in the setup?
i also have a KB racing manifold and billet turbo on the way for this truck
Are you seeing 20lbs all the way to redline with the 76/65, or does it peak at 20 and drop off as rpm climbs?
Old Jul 7, 2014 | 11:57 AM
  #118
denmah's Avatar
Moderator
it actually held 20lbs the whole way, im still not convinced that these are accurate turbo results, as i can only do 515-540 with the 76mm turbo also, something else might be capping my setup, possibly incorrect camshaft
Old Jul 7, 2014 | 12:01 PM
  #119
FrossB's Avatar
I hope that is the case! Im really looking forward to this turbo for my build. But I want more than 500hp...obviously haha
Old Jul 7, 2014 | 01:05 PM
  #120
I8URLS1's Avatar
Yeah I think something else may be at play here. I know one guy made 765whp with the 76 on a 6 speed car. I would like for these to at least support 750whp each as I'm using them in a twin setup. I wanted to give them a shot and later I will swap them out with some billet wheel turbos.
