spark plug gap?????????????
Old Jun 17, 2014 | 08:46 PM
SPOOLED UP's Avatar
Default spark plug gap?????????????
lq4 stock long block with tu1 cam and springs
80mm turbo 80lb inj on e85
th400 3.27 gear
what should i gap at and wanting to push 18-22lbs
.025"??
Old Jun 17, 2014 | 09:14 PM
denmah's Avatar
Moderator
yeah strait to 24 youll be mint
denmah's Avatar
Moderator
tr6 or br7ef is close to that gap right out of the box lol
Old Jun 17, 2014 | 09:26 PM
SPOOLED UP's Avatar
Is this sarcasm as in blow it up real quick???
I have the br7ef already and dont want to guess gap.
Old Jun 17, 2014 | 10:17 PM
denmah's Avatar
Moderator
i always gap right to 24, lots of people want to **** around and do like 38,32,28 etc
if you are gunna run 20lbs save yourself the hassle, gap right to 22-24 and be done
all of my 20-22lb setups run a TR6 at 23~ gap problem free
Old Jun 17, 2014 | 10:21 PM
willizm's Avatar
.025 gap here. No issues at 20+psi on e85. I run b8efs plugs.
Old Jun 18, 2014 | 02:49 AM
Boosted Firehawk's Avatar
Hey Will why not br7ef ?
Old Jun 18, 2014 | 05:33 AM
Camaro9969's Avatar
Just get br7s take them out of the box and throw them in no need to touch the gap have ran 22psi with no problems
Old Jun 18, 2014 | 07:28 AM
willizm's Avatar
Just wanted to try a colder plug out as my br7efs were breaking up at higher boost. The gap was .028 and after switching and tightening the gap I've had 0 issues.
Old Jun 18, 2014 | 01:36 PM
SPOOLED UP's Avatar
GOtcha Will.... But do you think if you kept the 7s and tightened up the gap you could possibly have 0 issues?
Old Jun 18, 2014 | 03:04 PM
willizm's Avatar
Probably wouldn't have a problem with 7's gapped to .023-.024. Changing my plugs with stainless works headers is a PITA so I just went a step colder with a .025. Every cars a little different but you'll find a gap and plug that works. Most seem to have great luck with the 7's in that gap range though so it's a good place to start.
BTW, just saw you are running 80lb injectors. You may need to look at bigger injectors if you're pushing 20+ psi on e85. FWIW I'm running 2000cc injectors and my DC on 22psi is around 71-72% IIRC. You could probably get away with 1300cc or 1600cc injectors and still have some overhead.
Old Jun 19, 2014 | 02:08 PM
Y not just bump up the line psi instead of running huge injectors?
Twin pumps at say 70psi with 80s
