Turbo 5.3 with big cam.
specs are.
Compressor Wheel 76mm .80 a/r 4” Inlet and 2.5” Compressor Outlet Inducer- 76.71mm Exducer- 102.36mm
Exhaust Side:
Exhaust Housing T-4 Flanged Divided Available in 2 A/R sizes - .81 3.0" Vband outlet Inducer- 74.5mm Exducer- 60.56mm
Before I take this cam out I really need to know what you guys think and if it carry 6500 rpm with this setup. or if a stock ls1 cam or ls6 cam would be better.
Exhaust Side:
I am just needing some expert advise. I am hearing 2 different things and have researched it and found that big cams seem to gain with boost but you have to have the right turbo. I don't want to build this with the ms3 cam and it only makes 450 horse. Cause I know a triple 12 cam or even a ls6 cam can make 620-650 with this turbo. But since the motor is all together I was going to try it with the ms3 and see what happens but im unsure at this point. please help.
That turbo will choke out even a stock cam. Keep your cam, gears, and converter, and get a BW S 475 / 96 1.32, since they are cheap. And if you want to spend a tiny bit more, get the 1.1a/r ex housing for it from Forced Inductions.
Then you will have a monster that happily revs and shifts at 71-7200.
My .02
My .02
You dont really need much cam to get your engine to out flow the exhaust side of the turbo, I ran the 212-212 112 cam on my 4.8 with a 78/75 1.15 turbo, it made 730rw with an open loose converter. I shifted it at 6500 but it peaked out at 5800 on the dyno. 1.60 short time off the foot brake in a full size truck. What im getting at is setup your cam to spool the turbo, don't worry about 10 extra hp up top that's what we got boost for! You can hit 600rw with that turbo you will just have to shift at 5500
I picked up .5 of a second and 8 mph switching from an ls7 cam to a custom tick cam in my 5.3 with a on3 76mm on the same boost.On paper it makes 1 hp but I don't give a **** what the dyno says, at the track it's night and day differance and even better on the street. Best 400 I spent!!!!! 10.15@134mph on 12.5 lbs
#34
ok was wrong on the turbo I have. It is a 81ar inlet and 1.00 exhaust. 76mm turbo. I think I might try it as I have it all already. It might choke up top with over 15 psi but I am only looking for 9-10 psi or 525 to 550 horsepower at the wheels. what do you guys think.
#35
Dyno comparison on my 4.8 with borg s366 turbo and a 238/244 dura, 605/612 lift, 114+2 vs ls6 cam. The big cam is the red dyno file and ls6 is the blue file. http://s1105.photobucket.com/user/fbodyjunkie06/media/StevenSigmoncompare_zps42a612c9.jpg.html
#37
so it looks like power was similar above 5k. that is not bad numbers for 8.5 psi. And a 5.3 should make 20-30 more horsepower then a 4.8. So even with my small turbo 500 at the wheels on 9-10 psi should be doable and since my converter flashes to around 3600-3800 it might run good.
#38
