Turbo 5.3 with big cam.
it also depends on your convertor and trans. to get it spooled. if you cant get it out of the hole it wont et very good. you can try pming stock48 he is a good guy and he could give you a better idea. he might post as well. .
My guess would be 50rwhp midrange, 20rwhp up top and 500rpm later spooling. But it'll sound sick though!
You have any idle clips? i bet that thing thumps.
the key is selecting a turbo to compliment the rpm range the cam/engine dictates, and setting up the drive train to take advantage of the rpm range that your cam/engine/turbo combo give you.
I personally think your combo will be fine, BUT the turbo will choke before the engine is done, and when you step up to a good flowing turbo, you will need a very good converter.
what are the exact specs of the turbo?
