Opinions needed... 5.3 with a s480
Old Jul 1, 2014 | 12:41 PM
from9rto1k's Avatar
Default Opinions needed... 5.3 with a s480
I checked but none of these post are exact what i have i did search first
I got the billet wheel s480 t6 twin scroll... With a bugger turbo cam on a stock 5.3 how will spool time be would u think,?
Old Jul 1, 2014 | 02:38 PM
from9rto1k's Avatar
Sorry 96mm with 1.32 ar...
Old Jul 1, 2014 | 03:01 PM
dezlfrek's Avatar
cam makes a big difference.. should tear your head off by 3500 to 4k lol
Old Jul 1, 2014 | 04:00 PM
from9rto1k's Avatar
Thats what im hoping
Old Jul 3, 2014 | 08:17 AM
Sarg's Avatar
With the 96 I would expect 4000-4500 depending on gear. Keep the charge pipes small and divided. It should still work. Get the right cam and converter.
Old Jul 3, 2014 | 12:35 PM
Beatdown Z's Avatar
5.3 with a standard S480 in my brother's car comes on around 4000rpm and builds boost with rpm like a supercharger. It has the wrong cam, converter, and oversized hotside.
With the right components, it would be a lot better.
Old Jul 3, 2014 | 02:07 PM
from9rto1k's Avatar
2.5 hot side divided and convertor being built for motor and cam etc
Old Jul 3, 2014 | 09:38 PM
Blackpanther99's Avatar
Any track times with his setup?
Old Jul 4, 2014 | 11:41 PM
Orangemagic's Avatar
2.5 hot side is probably to big. Run a 2.25 hot side. Get a custom cam spec'd that knows what your intentions are with the car and a loose stall that hits hard around 3800-4000.
Old Jul 5, 2014 | 08:33 AM
denmah's Avatar
Moderator
2 inch hotside, divided to the turbo, and a isky 212 cam for big down low if you are worried about bottom end
Old Jul 5, 2014 | 09:52 AM
turboventura's Avatar
Denmah, your buddy with the foxbody did that spool valve setup that was basically both sides merged into one half of the turbine housing, then a wastegate that went from the drivers side manifold over to the other half of the turbine. Was that worth the trouble you think or is it better to just stay divided?
