need help map sensor not working correctly
Old Jul 5, 2014 | 12:12 PM
askkmb's Avatar
Default need help map sensor not working correctly
Hello guys, i need some help. My map sensor is supposed to be a 3 bar but it only shows 15.2 psi at max. Im running 11 psi according to the boost gauge. At idle the map shows 8 psi, and when i start to boost it, the boost gauge shows 2 psi and thats when my map is at 15.2 and it stays there even when i actually run more boost. Any help appreciated. Heres a log file and the tune. The tune is no good yet but i first need to figure this out before tuning it out more. The map sensor is already the 2nd one i put on there but makes no difference. Thanks.
File Type: hpl
File Type: hpt
Old Jul 5, 2014 | 03:11 PM
Shoaf85's Avatar
Which map sensor are you running?
Old Jul 5, 2014 | 03:15 PM
askkmb's Avatar
A 3.3 bar that i bought from smart fire injectors.
Old Jul 5, 2014 | 03:18 PM
Shoaf85's Avatar
You need to add/insert the 3bar map sensor into your table (primary) in the scanner in order to read higher than 105kpa which is all the factory sensor is good for. Also change your boost enrichment table in the tune immediately before damage is caused from running lean. Right now you are commanding 14.7afr at all boost levels.
Old Jul 5, 2014 | 03:19 PM
Shoaf85's Avatar
Did you get the correct sensor kpa and offset values to enter into the tune?
Old Jul 5, 2014 | 03:24 PM
Shoaf85's Avatar
Also your timing tables need some work. You are commanding negative timing values in the upper range of your tables. To start I would change all cells to 14* between .64 airmass to 1.20 from 4000rpm and up
Old Jul 5, 2014 | 05:45 PM
askkmb's Avatar
Thank you very much! I got the sensor kpa and offset values but im not sure were i do enter them. Any help there would be apreciated. And i just changed the timing like you said and changed my config in the scanner. Im about to try how it works now and ill let you know.
Old Jul 5, 2014 | 09:59 PM
Shoaf85's Avatar
to change the MAP sensor values open your tune,click on Engine Diag tab > Airflow tab > in this area is where you will see the map sensor linear and map sensor offset values. Just enter in the data as you received it in the corresponding tables.
Old Jul 7, 2014 | 08:27 PM
askkmb's Avatar
Okay thank you very much! I just did some tuning and it works way better now. Thanks once again!
Old Jul 7, 2014 | 09:06 PM
Shoaf85's Avatar
No problem man....you can pm me if you have any other questions.
