Injectors for L33 S475
Old 07-13-2014, 10:00 PM
CarrBoost83's Avatar
Default Injectors for L33 S475
I am in need of injectors, engine is currently being dropped in, running stock rails and stock truck manifold, turbo is a Borg Warner S475 1.32 housing for now, running a walbro 255 for now also, will eventually run 2 255s, so I need some input on what injectors I need, 60's?80's? Will only be running 6-10 psi max. So a better answer that iam looking for is what ones will work with the stock setup? Want to keep the stock look. Thanks
Old 07-14-2014, 06:18 AM
yenkomike's Avatar
siemens deka 80# are hard to beat. you will need to shim up the fuel rails about 5/8 .I used them with all my stock truck intake /ruel rails. and for under $350 there will give you room to grow. they run and idle so good there is really no reason to go smaller. jmho.
Old 07-14-2014, 08:55 AM
Restricted User
JoeNova's Avatar
Couldn't agree more, and the direction that I went myself.
Old 07-14-2014, 11:46 AM
MonmouthCtyLS7's Avatar
Siemen Deka 80's here also.
Old 07-14-2014, 01:09 PM
80s were on my mind just wasnt quit sure, anyone have a part # thanks alot for the feedback also!!
Old 07-14-2014, 01:13 PM
and shimming the rail? like where the hold down bolts to the manifold? just have to use washers or whatever because of injector height?
Old 07-14-2014, 01:27 PM
yenkomike's Avatar
yes just shim the rail up as the deka's are taller. but there are a few ways. i just measured the differance in injectors height and made them out of a longer heavy wall pipe and cut to length.
Old 07-14-2014, 06:30 PM
cool thanks ill be ordering a set of those some time this week then, are they ok to start the engine with or should i get a tune file for that also??
Old 08-22-2014, 10:39 PM
so after awhile of not getting anything accomplished i fired the engine with the stock injectors and just let it ilde and did the normal checks on everything. so iam back in the hunt for injectors, i am going to rub #80s but the question i have is that all injectors i find are for EV1 and EV6 style connectors, the ones on my truck are Delphi connectors, am i missing something? will one of those work with my style of connector?
Old 08-23-2014, 07:13 AM
etijsma's Avatar
Get adapters. They have ones that have pigtails that you solder on and there are ones that go in between the two.
Old 08-23-2014, 12:25 PM
samdogmx's Avatar
at only 10 psi of boost on gas the 60's will be fine
Quick Reply: Injectors for L33 S475
