Look over my tune?
Could you guys look over this tune and let me know what you think?
First time tuning and i'm a little hesitant with the timing and boost with the higher compression from these heads.
Any feedback or tips would be awesome!!
Car is a 98 Camaro Running a 2 bar SD tune
Stock ls1 with rod bolts
Stage 2 Patriot heads
224/563 cam
ls6 intake with 60 lb deka
Single racetronix pump with hotwire kit
Front mount truck manifold kit
On3 76
Running 91 with a Progressive methanol kit on a size 7 nozzle
I'm running 50/50 meth with it set to come on at 2-3 psi and full on at 10-12 psi which it probably won't ever see.
The timing is the scariest thing for me, i'm not sure how to go about properly scaling the table or if there's a Histogram for that type of thing. I've heard things like you should take out 1 degree for every 2 psi or 1-1 but that seems like it would be too high seen as the N/A tune had 29-31 degrees where i'm only seeing 13 degrees, And i'm only seeing about 8 psi. I'd rather be safe and leave a little on the table.
I'm currently trying to lean out the AFR's a little, i've got the PE table set to 11.3 but it never gets that lean, i'm assuming the meth is the reason for this. I think i've got the VE table pretty good as it cruises pretty well but it gets a little tough trying to dial that in because it seems the car gets lean after it gets hot then screws up all the readings. I extended my IAT sensor and moved it down by the fuse box area and it seemed to help but i still get that sometimes. It does seem to help to get on it enough for the meth to activate and then the AFR's come back in line.
Also does all the injector data look correct? They are siemens deka 60lb.
So anyone have any opinions or advice on where to go with my timing table?
If you still want help post up some logs and we can discuss.
I'm also new to tuning but from what I've read this seems to be a good way to go.
