Huron Speed - Your #1 Turbonetics Supplier!
Which GT55 turbo were you looking at? There are tons of options out there on GT55s so let me know and we can go from there!
The Y2k's I have on the shelf have the BILLET 88mm compressor wheel, Ball Bearing Center Cartridge, and the 101mm exducer and 108mm inducer turbine wheel with 5" discharge on either a 1.23 or 1.39 a/r
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic36191_1.gif)
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Size wise I don't have a GT55 here but it appears the compressor cover on a GT55 would be a touch larger, but not a lot.
The better question would be what are you using the turbo for and what are your goals?
__________________
I did a little digging and found these for you! Product drawing for each!
Y2k Drawing: http://www.turboneticsinc.com/perfor...2K_TURBO_0.pdf
GT55 Drawing (Click the Drawing Tab): http://www.turbobygarrett.com/turbob...r#GT5533R%20(1)
__________________
I know they have a new mid-frame in the works, I will try to get more info on it for you!
__________________
Turbonetics' new mid-frame will pack an 75, 79, or 83mm Billet compressor wheel coupled with 87.6mm inducer/ 82mm exducer turbine wheel.
So far: We made over 900whp and our testers dyno couldn’t register anything more since it maxed his dyno at 1100lb/ft of tq. That was only at 22psi on an LS-motor.
__________________
#32
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
best Co i have ever dealt with by far, even answered my e mails on sunday the out come was a the billet y2k with exhaust side coated at a awesome price and t6 kit soon to come, definately a happy customer,
Thanks again Richard
#33
With the design of the wheels and larger housing I am a firm believer it will out perform a PT88, however it is physically larger as the Turbonetics mid-frame uses the y2K compressor cover. With this, the fit of a PT88 will be a lot better, much more compact.
__________________
#34
Jon
__________________
#35
So would that mean that it would not fit with your kit or that it would just be tight fit?
#36
The Turbonetics Mid-frame with the y2K large compressor cover will not clear on the T4 kit without some mods.... it is a BIG T4 in comparison to others.
__________________
#37
