S10 377 Ram S480
Old Jan 18, 2015 | 06:26 PM
LVTUNER's Avatar
Default Update 2015
Installed M/T 30" tall drag radial tires and hitting 15# of boost now. It spools fast and blows the tire off until you lift. Fun is right but spinning is not winning and thats all it does right now. AMS boost controller is on the list. Adding some weight and adjusting the Cal-trac. Installed a 4" Magnaflow muffler and got rid of the fender exit. Hey Joe I made good use of your stickers HVH.
Attached Thumbnails S10 377 Ram S480-s10-turbo-tire.jpg   S10 377 Ram S480-new-down-pipe5.jpg   S10 377 Ram S480-new-down-pipe6.jpg   S10 377 Ram S480-magna-muf-s10.jpg
Old Jan 18, 2015 | 10:43 PM
IronBlocked's Avatar
Wow it's a thumper eh! great truck
Old Jan 30, 2015 | 07:02 PM
LVTUNER's Avatar
Default Boost Control
Thanks Ironblocked.
Went BIG on the boost controller and purchased the AMS2000 PRO. I started the install by drilling and tapping the wastegate for the 100 psi pressure sensor. Could tee it in. Then I found a mounting location for the solenoids. Thats were I am at now.
Attached Thumbnails S10 377 Ram S480-photo-10-.jpg   S10 377 Ram S480-co2-bottle.jpg   S10 377 Ram S480-photo-12-.jpg   S10 377 Ram S480-new_ams-2000-componentsps.jpg
Old Jan 31, 2015 | 10:58 AM
SS-TEN's Avatar
Looks good, man! Do you plan on doing a dyno tune?
Old Apr 22, 2016 | 03:09 PM
m8w6r77's Avatar
bring this back. lol. how do you turn with the downpipe in there? I was thinking of keeping it tight by the control arm and go under the frame to run it back on the inside of the frame. is that possible?
Old Apr 22, 2016 | 04:05 PM
LVTUNER's Avatar
You are correct, turning was tight and decided to change the exhaust again. Sold the engine and just about finished building another 377 for it. Thinking about going to a fender exit on a cut-out and small 2 1/2" exhaust going out the back.
Old Apr 23, 2016 | 10:32 AM
rpturbo's Avatar
I would like to see some more under hood pics!
Old Apr 23, 2016 | 02:22 PM
LVTUNER's Avatar
The only 2 pics I could find on this computer, I will take more when putting her back to together.
Attached Thumbnails S10 377 Ram S480-turbos10.jpg   S10 377 Ram S480-photo-2-.jpg
