Question about S480
Old Sep 7, 2014 | 09:30 AM
2BAD4U's Avatar
Default Question about S480
So I've got a S480. I'm looking at wanting to go to billet wheel. I've heard of billet 83mm. I'm assuming I could have that installed but I'm also assuming my housing would need machined aswell? So my questions are, what are my options? Who has changed to billet? How much did it help? Who or where should I send my turbo off to?
thanks...
Old Sep 7, 2014 | 02:31 PM
408GT's Avatar
Talk to Jose at forced induction. He'll get you on the right track.
Old Sep 7, 2014 | 02:48 PM
2BAD4U's Avatar
Okay perfect! Thank you... you have link or number for him?
Old Sep 7, 2014 | 03:54 PM
MonmouthCtyLS7's Avatar
forcedinductions.com he's a vendor here
Old Sep 7, 2014 | 04:09 PM
2BAD4U's Avatar
Thank you... I will call him tomorrow. You know anyone who has changed it out to a billet wheel? Curious to know if the juice is worth the squeeze?
Old Sep 7, 2014 | 05:40 PM
Forcefed86's Avatar
What are the specs of the 80 you have now and what is it installed on? How much boost do you run now and at what RPM? How much power do you make now and how much do you want to make?
Old Sep 7, 2014 | 11:05 PM
Forcefed86's Avatar
Originally Posted by 2BAD4U
Built 347, 25psi 1xxxwhp goal. made 782 on 16psi far as specs on 80 not sure as bought kit off buddy who never ran it. All I know is its a S480 with cast wheel and non race cover. I "think" it has 87mm turbine wheel.
So your at 25psi now or thats what you plan to run? What are you reving it to?
Only reason I asked is most people looking to upgrade their 80mm cast wheels aren't pushing the cast wheel to near it's potential. That also depends on the hotside of the turbo. IMO you should be able to make 1000whp no problem on a 347 setup up properly. Hard to say with the info given, but very mild factory headed 370ci LS motors are making 1000+ with the right 76mm turbo around 25lbs. Id' think a 347 with nice heads and cam wouldn't have a problem doing the same.
Old Sep 8, 2014 | 08:22 AM
2BAD4U's Avatar
I've pushed it to 22# on street with c16. Not on dyno yet. Motor is built around boost. But like I say I'm just curious more of what the difference it would make going from cast 80 to billet 83? Who's done it? Did they like it? Did it spool better? How much did it cost? Ect. I mean realistically a dyno is just a number. That's all... Performance of a car and track results are to me what counts. Guess here in a couple hrs. I just need to call Jose and ask him these questions.
Old Sep 8, 2014 | 08:48 AM
Forcefed86's Avatar
I agree, dyno racing is silly. I was suggesting you max out what you have before looking at upgrades. A cast 80 will put out some serious power and will act slightly different on every setup as far as it’s maxed out potential.
I gained 5mph at the same boost level (25lbs) going from a cast s475 to a billet S476. But I went larger on the exh wheel and AR housing as well. From my buick turbo days, bumping the comp wheel alone (billet or not) isn’t usually worth monster gains. Upgrading just the compressor did make slightly more power, but it always slowed spool and raised backpressure for me. (It takes bigger “bites” of air and is harder to turn) Ideally you should go larger on the exh wheel to match the new larger comp wheel then up the housing size as well to see huge gains.
Old Sep 8, 2014 | 09:17 AM
2BAD4U's Avatar
that's good input. Thank you. That's kinda what I've heard to about the billet wheels. I really don't want to push it much past 25# on a 4 bolt head. Yeah it's o ringed but still... So I just might pull it off and see what exhaust wheel is on it. I'm afraid it's the smaller 87mm though.
Old Sep 8, 2014 | 09:37 AM
Forcefed86's Avatar
The base model S480s usually have the 1.32 AR T6 and 96/87 wheel. That’s the “big” wheel and the one you’d want if you plan on upgrading. IMO as long as your Exh minor dia. is larger than your compressor minor diameter your good to go. A larger billet 83 compressor would shine on that turbo.
Wouldn't get too caught up in any specific boost pressure limits either. It’s overall cylinder pressure that lifts a head. Boost alone is a very small part of it. With the right fuel, CC design, cam, and RPM… I’m sure you could run 40+lbs of boost without lifting a 4 bolt head. Boost pressure is similar to dyno readings… just a number.
Old Sep 8, 2014 | 11:48 AM
2BAD4U's Avatar
very true... it's (manifold) back pressure. Not cylinder... Realistically my weak link is factory aluminum block.
Old Sep 8, 2014 | 03:06 PM
LilJohn's Avatar
If its got the 87mm inducer turbine wheel.... Just sell it and buy one with the 96/88mm turbine wheel. you will need it to make 1k+ at the tire.
A Cast 80mm compressor with a race cover combine with the 96/1.32 turbine averages about 1000-1050 rwhp set on kill with the gates pinned shut....
The Forced inductions Billet wheels for those turbochargers are worth an additional 200-250 rwhp over the stock cast wheels and they make an additional 4-8 psi with the gates pinned as well.
Old Sep 8, 2014 | 03:49 PM
2BAD4U's Avatar
GREAT info... Thank you
