breaks up under load
Old Sep 21, 2014 | 02:23 PM
yelo04goat's Avatar
Default breaks up under load
need some ideas on where this issue is coming form.
2004 GTO forged 347 78mm turbo 4l80 9.6:1 compression 230ish cam 3400ish stall.
in park the car free revs fine, snappy response idles and revs fine. even when snapinging the throttle open and closed quickly..
once it is put in gear the idle gets rougher, and if there is any load it will break up and show lean on AFR guage. something new is the gas pedal feels like it is pushing back when it does it. its cable not electronic.
im at a loss where to look. new crank and cam sensors along with 3 bar MAP sensor.
not sure what else to say need any more info just tell me here is a copy of the current tune and a basic log I need to set up new configs still ..
any help will be accepted!!
21sep_1.hpl
21sep_91base.hpt
Old Sep 21, 2014 | 05:26 PM
denmah's Avatar
Moderator
only thing i see thats interesting is p0016 is disabled, crank position code?
other than that i dont have much experience with that year ECU and upgrade
Old Sep 21, 2014 | 06:49 PM
pwrtrip75's Avatar
Spark plugs? What kind? Part number? and what do they look like?
Old Sep 21, 2014 | 07:11 PM
yelo04goat's Avatar
Ngk bre7 .026 gap. Were brand new when put in. Looked fine when i had them out maybe hour total run time on them if that
Old Sep 21, 2014 | 07:13 PM
Sickness7's Avatar
Attachment 470071
Attachment 470072
Check if all the spark plug wires are fully on. This used to happen to me.
Old Sep 21, 2014 | 07:43 PM
dmaxvaz's Avatar
Gap them to like .017 and see what happens.
Old Sep 21, 2014 | 11:13 PM
yelo04goat's Avatar
that seems tight.. I mean its not even getting to boost could that really be the problem?
Old Sep 21, 2014 | 11:58 PM
ghost-1's Avatar
Ohm plug wires had the same issue like 5 plug wires were in the 500+ range and should have beeen in the 40 low 50 range.
Old Sep 22, 2014 | 10:59 AM
dmaxvaz's Avatar
Works for me even at 20 psi boost.
Old Sep 22, 2014 | 11:16 AM
oscs's Avatar
My stock spark plug wires where over 900 ohms. Pull a few and check
Old Sep 24, 2014 | 08:19 PM
yelo04goat's Avatar
Well i know they are gunna be high the are autozone wires. I have to use longer wires. I need to buy some better wires i know. I didnt think it would be an issue just to get running
Old Sep 24, 2014 | 08:26 PM
Wicked69's Avatar
My vote is the wires. Get some used stock ones you know aren't burnt and just try them and see what happens.
Old Sep 24, 2014 | 08:33 PM
oscs's Avatar
You know what is much easier to find than a set of known good used spark plug wires? One of these. Test your wires before you spend a dime on another set
Old Sep 24, 2014 | 11:22 PM
yelo04goat's Avatar
i have to use LT wires the way we built the hot side on the driver side. so ill have to hunt down some good one.
Old Sep 25, 2014 | 07:22 AM
Ryans99ls1's Avatar
Hows your voltage on the car? My car was pretty low on voltage (9-10v) and it really messed with my injectors. it was fine driving around but as soon as it transitioned into boost, it broke up really bad.
Old Sep 25, 2014 | 10:45 AM
wild1100's Avatar
Default at night
Had same issue. Wait till night time with hood up have someone sit in seat footbrake dont break tires loose just load car. Watch plug wires there will be a arch some where. I run same plugs .35 gap. Ohmed wires still had issue. Then was told to wait till dark have wife footbrake car and sure enough only under load I had 1 arch off header. Headers were wrapped to amazing.
Old Sep 25, 2014 | 11:10 AM
oscs's Avatar
Great info. I would have never thought of that.
Old Sep 25, 2014 | 01:04 PM
yelo04goat's Avatar
I will have to try that..
Old Sep 25, 2014 | 02:36 PM
69-chvl's Avatar
If you do it on a rainy/damp day or maybe even spray a mist on the engine you can really see an arc.
Old Sep 25, 2014 | 03:23 PM
Hank Peabody's Avatar
Spray some starting fluid in there for a fireworks show!
