Drivetrain loss
Old Sep 25, 2014 | 08:13 AM
oscs's Avatar
Default Drivetrain loss
I've always been curious. What is the percentage difference in HP loss for the T56 vs. 4l80e I know a few of you have switched over and I'm curious how much of difference there is.
Old Sep 25, 2014 | 08:29 AM
HCI2000SS's Avatar
I remember hearing one time it was like 3-5 percent more
Old Sep 25, 2014 | 09:09 AM
oscs's Avatar
That's not that bad. The way people talk about the two you'd think it was 10-15% difference.
Old Sep 25, 2014 | 09:17 AM
JoeNova's Avatar
Restricted User
Drive train loss is most often seen at the dyno and not at the track, especially in the case of auto transmissions.
Old Sep 25, 2014 | 10:06 AM
NorthTexasConverter's Avatar
Really just depends on the build. A 4L80E we build will have less parasitic power loss vs a stock 80E because we rollerize them. Some of the bigger power guys who have an aluminum have a much lighter drum shedding a few pounds from the internal rotating weight, decreasing loss further. There is even more you can do beyond that for even less power loss when all said and done. Converter selection, stall and setup all have an effect on power output as well
Old Sep 25, 2014 | 11:14 AM
rotary1307cc's Avatar
An 80e will dyno like a hero locked up. Its not like a glide or 400
Old Sep 25, 2014 | 11:25 AM
oscs's Avatar
Has anyone here done a direct comparison between a built 80 vs. t56 or 6060?
Old Sep 25, 2014 | 01:23 PM
95bowtie's Avatar
I know this much.....a th400 only showed a little over 600 at the wheels but goes 10.35 at 135 with a 1.70 60ft in a 3700# car lol. Seems like a auto unlocked will dampen the dyno numbers a bit but not the e/t
Old Sep 25, 2014 | 02:28 PM
denmah's Avatar
Moderator
actually had a LS2 on a engine dyno, it did 440 average and then put down 365 wheel with a 65e to the tire, so i was actually surprised with the 23% loss!
Old Sep 25, 2014 | 05:13 PM
oscs's Avatar
What trans where you using with the 440 numbers?
Old Sep 25, 2014 | 05:54 PM
C5natie's Avatar
I think he said engine dyno so no trans. Then a 23% loss with a 4l60e
Anyone running a multiclutch lockup cconverter? I know with my Circle D locked up I saw a 70 ft lb gain vs my old Yank.
Old Sep 25, 2014 | 06:00 PM
oscs's Avatar
Originally Posted by C5natie
I think he said engine dyno so no trans. Then a 23% loss with a 4l60e Anyone running a multiclutch lockup cconverter? I know with my Circle D locked up I saw a 70 ft lb gain vs my old Yank.
Yeah missed that part, thanks.
Old Sep 25, 2014 | 08:09 PM
ken6881's Avatar
23% trans, rear end, and tires. Just saying trans is not the only thing eating HP.
Old Sep 26, 2014 | 10:11 AM
And converter!
Old Sep 26, 2014 | 01:35 PM
JoeNova's Avatar
Restricted User
Was the converter locked Matt?
Old Sep 26, 2014 | 02:10 PM
denmah's Avatar
Moderator
unlocked stock ls2 gto setup
on a engine dyno, flywheel bolted directly to dyno hub, with longtubes on the motor as it sits in the car. but 440ish average wheel hp
then on a dynojet 224x (my dyno) 350~ average on many pulls,
but unlocked stock converter, 60e, to the tire.
23%
i would love to take one of my turbo cars that makes 850whp thru a th400 and see actually what an engine dyno puts down with one of these things haha
