dedicated turbo oil system, Ideas and inputs welcome
So I've just been brainstorming some turbo oiling system ideas, and what I've got so far for a front mount turbo that is at the same level as the intake. is using an external belt drive wet sump pump, building a baffled oil tank (1.5 gallons) with feed and return ports possibly a filter on the tank if not a remote mount filter, and running the feed line to the pump and then the pressure side of the pump to the turbo and then turbo drains back into the tank.
thinking about using a pump like this but I'm not sure what the crank pulley spacing is like. I would want to keep the oil pump in the engine on its own system so that if the engine pump fails then i don't ruin the turbo from oil starvation or metal shavings.
Any ideas or comments welcome
this is a lot of money and complication just trying to save a buck on turbo rebuild.
if the engine oil pump fails you will have a failed engine, and sometimes that takes out the turbo on its own.
if i was (i am on my build) going through all of this expense and complication for an external oil pump, it would damn sure be for protecting the actual engine than the turbo.
sorry if that does not help you if you are fixed on your reasoning.
if i had to do it, id use a small electric pump. 60psi at low volume is easy to come by. and cheaper and easier to incorporate.
you could also go oil-less. no oil to cross contaminate there.
you're probably better off just running a scavenge pump and a small tank to the turbo, rather than setting up external oil etc
some people just run a filter on the oil feed for the turbo
other people just put the loud pedal down ***** out
