2002 Camaro SS AC Retaining Turbo Build
I am currently mounting my hotside. And so far its been a pain in the ***. Thanks to the tight spaces. After reading a few Huron Speed AC V1 kit users from south texas, and their overheating issues. I decided to relocate and go with a smaller condenser. My setup actually started as a truck manifold kit. Then I got the AC hotside.
Notched and painted bumper support.
I/C Mounted.
Cold side 99% complete.
IMO I would look to ditch the MAF and just run SD. Tuning other boosted setups on the ECM the Fbody uses or similar you end up getting weird overlap and fueling acts goofy most of the time. Second you hit any sort of boost your going to max it out anyway making it near impossible to maintain the afr.
I've only checked out what the WB said once in the last month I have been driving the car and not much if anything has changed at all. Brother in Law's MAF died on his bolt on Camaro so we just went the easy route and threw on an SD tune and he drove it year round without any issues. Even threw in the WB in December when he was out playing around and it read damn near the same as it did earlier in the summer.
If you were driving cross country with elevation changes and fuel changing on the way SD would have it's drawbacks but if you are staying within the region you honestly shouldn't have any issue.
Just my .02.
Thing I like most about having HPT is if something is wrong I know about it, if I can see what's wrong, I can fix it. Just like having a scanner, you can see the trouble codes or sensor being out of wack from a change, but can't do anything about it.
Was just tunning my buddies 11 Cts V and after he did headers he swapped the sensors for the O2 on one side by mistake. Not only did I see the code pop up, but could log the sensor in real time, see it was zero, and figured out it wasn't plugged in. All GM vehicles run off the same principal, just more sensors/options get thrown in. Honestly the fbody is the best to start with imo, has plenty of tables you can make changes and see them happen.
Honestly having the wideband you are already half way to doing your own tuning.
Are you planning to log the AFR or just use it as something to monitor in case there is an issue? If you are going to monitor it then you would probably be better off running the cable through the firewall down by where the pedals are, can drill a small hole and grommet the cable and it should put you close to where the WB will plug in with the exhaust. You can also go down through the trans/shifter boot or run it through the main grommet the PCM harness goes through over behind the passenger kick panel.
If you want to really get tricky and not cut anything, you can run the wires down through the door jam to the front fender. There is a small hole where the inner shroud meets with the bottom kick panels that the sensors usually will fit through, then can run the cable behind the shroud and wherever else you need it to go. I run my NGK AFX this way just because I bounce it between so many different cars and don't always run with it.
If you are going to data log would be easiest to run it through the passenger side just because it gives plenty of spots to have the cables out and stow them away when they aren't needed.
I'm sorry SVG210 but it looks like I'm SOL on the sway bar. I bolted it up and it's sketch big time. It hangs down lower than the K-member so I'm thinking its no bueno but I'm going to start a thread and see what comes up. I tried flipping it over and too and its not looking good which really sucks because I want a front sway bar. I never heard from that guy who said just lower it and he never sent pics so I'm thinking he was full of it. I have some ideas but they require some serious fab work and money which I'm out of.
Gauges installed into pod and pod mounted to A pillar cover.
Added hole under Harness bulkhead for O2 Harness.
Power wire for AFR Guage. Second row up, far left.
Ground terminal by hood release behind kick panel.
Boost gauge backlight tied into headlight harness.
Completed install.
So while I had the inside apart like this I went ahead and installed the Racetronix Kit which is an excellent kit! Includes everything for install, all the zip ties, all connections are clearly labeled and it even includes and extra fuse in case you make a mistake! Luckily for me the previous owner cut an access panel in the floor so I didn't have to drop the tank, sweet. So take the fuel tank end of the harness and fold back one connector and using electrical tape wrap it up so as to reduce the diameter of the harness so you can feed it up from the bottom of the car to the fuel tank. Start about the middle but favoring the passenger side of the car especially since if doing a turbo build since the alternator is now on the passenger side of the car. Feed the harness up next to the tank and plug into the factory harness. Then route along the underside of the car avoiding pinch points, moving parts and exhaust parts using the supplied zip ties to secure it. Route it up along the frame following the factory harness up to the alternator and attach to the back of the alternator. The ground is attached at back above the rear axle so just clean the paint off a spot and secure. Unbelievably easy. I'll attach more pics when I get back because my phone didn't seem to keep them. So after this I just need to secure the front brake lines, get an alignment, hook up the exhaust and get a Pat G tune. So close...
Thanks guys and please let me know if anyone has any questions!
