Making a Ported M90 Work?
Old Oct 15, 2014 | 08:47 PM
LSX Man's Avatar
Default Making a Ported M90 Work?
So I've got a M90 on the shelf in the garage, just sitting there.
I want to install it as remote mount on my ls1 swapped 91 camaro. It has a 236/238 601 camshaft with longtube headers.
From my understanding, a stock M90 will become a restriction at higher RPM's. So my question is, if I port the M90 as much as possible and use the correct size pulley, will I see gains all across the powerband? I am not looking for crazy high HP numbers at all. Simply, all I want is a really fun street car, with a supercharger whine.
Or, is there absolutely no hope with gains from a M90?
BTW, I want to retain my stock hood, therefore the M90 appeals to me because it is on the smaller size of the superchargers. I can always upgrade to a procharger or magnuson later down the road.
Old Oct 16, 2014 | 04:06 AM
pwr-346's Avatar
Its designed for 2-5lt engines. You'd be spinning that thing out of its efficiency range. They are factory fitted to our v6 commodores in Oz, most lucky to reach 250rwkw on a 3.8 buick.
Old Oct 16, 2014 | 05:28 AM
LS1-IROC's Avatar
You may gain a little torque down low, but after that it will be a restriction and dead weight. I wouldn't bother IMHO.
Old Oct 16, 2014 | 08:18 AM
SM105K's Avatar
https://ls1tech.com/forums/forced-in...5-m90-ls1.html
Old Oct 16, 2014 | 11:07 AM
Mongoose350's Avatar
If your dead set on it, a 5.3 might do better. Maybe even a 4.8.
Old Oct 16, 2014 | 05:54 PM
TT427's Avatar
Get another, 2 should work
Old Oct 16, 2014 | 07:35 PM
LSX Man's Avatar
Haha I would love to do two.
Looks like I am going to hold off until I can afford something larger.
Old Oct 17, 2014 | 02:30 PM
chuntington101's Avatar
Agreed! And look at Aston martins 90s vantage for some great ideas on mounting.
