Can this be done on pump gas?
Old Oct 18, 2014 | 01:06 PM
SpeedJunkee's Avatar
Default Can this be done on pump gas?
My motor is fully forged, 8.8:1 CR (LT1). I have a FMIC, and plan on running meth injection.
I am going to go with an 88mm turbo. I want to stay with pump gas because there is no E85 in my area, and it will not be a track car.
I want to make 800-1,000 at the tires. Can this be done safely on pump gas?
As a side question, what size and brand injectors would you recommend?
Old Oct 18, 2014 | 01:37 PM
krazy4's Avatar
Are you opposed to methanol injection?
That would make it a lot easier and safer.
Old Oct 18, 2014 | 02:29 PM
stevieturbo's Avatar
At that compression, as long as you've a good intercooler I dont see a problem making the power if the setup supports the numbers. Unless the gas available to you is totally horrific
Old Oct 18, 2014 | 07:12 PM
Read my post. I said I was planning on running meth and a FMIC.
Old Oct 18, 2014 | 07:14 PM
The octane here at premium is 93, so should be good (better than 91 or lower like other places).
Thanks for the input!
Old Oct 19, 2014 | 05:39 PM
denmah's Avatar
Moderator
check out the 403 + s484 thread i created
we are making 923 ish to the tire thru a th400 on 19psi and pump+meth
car traps 163 on 16psi! LOL
Old Oct 19, 2014 | 06:00 PM
Badass! I'll check it out, thanks.
