2012 cts-v noisey supercharger what the fix??
I have a 2012 cts-v. At my shop with a rattle in the super charger ...
I took of the supercharger belt and the noise goes away ...
I see gm extended the warranty on the supercharger ...
But this car has a branded title so the warranty is blocked ...
Is their a repair less expensive then replacing the entire unit ??
Looked into this with my buddies when it was making the rattling. Typically it is the coupler that starts to go. If it's really bad the bearings and seals have to be replaced.
If I remember correctly when the coupler starts to go it leaves slack in the bearings and seals and they need replaced, not just a matter of changing the $40 part. If you have a hydraulic press and can find the rebuild kit (Think my buddy found it for ~$400) you can rebuild it yourself. Honestly just better off picking up a used unit.
