Co2 on the street
Old Oct 28, 2014 | 06:48 AM
stevieturbo's Avatar
Unless you need to use less than spring pressure, ie sub 5-7psi, then I can see no point at all in adding the complexity of an external air pressure.
Old Oct 28, 2014 | 07:08 AM
oscs's Avatar
It's the control at lower psi that I'm after and the ability the pin my gates shut for max spool at any time. For the additional $120 and 10min install I'd say it's well worth absolute boost control.
