Co2 on the street
Old Oct 27, 2014 | 08:46 AM
oscs's Avatar
I'm considering a C02 setup on my waste gates to keep my twins spooling nicely with the 6spd and General better control of boost. I'm curious if any of you guys run C02 on the street and if you do how long does it last? My car is primarily a weekend warrior.
Old Oct 27, 2014 | 09:21 AM
JoeNova's Avatar
Restricted User
Intercooler sprayer?
Old Oct 27, 2014 | 09:25 AM
oscs's Avatar
Sorry forgot to mention that it is for waste gate control.
Old Oct 27, 2014 | 11:11 AM
Shoaf85's Avatar
I personally don't run C02 but a lot do on the street and I'm sure they will chime in. However an onboard air system is pretty cool and probably the route I will go when/if I feel I need it.
Old Oct 27, 2014 | 11:12 AM
oscs's Avatar
Any more info on this?
Old Oct 27, 2014 | 11:14 AM
98no2maro's Avatar
I run an AMS-1000 with co2 on the street. I have a 2.5lb bottle. It takes a long time to use a full bottle. The bottle i have now has 26 dyno pulls on it and ive been driving the car for 8 months and the bottle pressure has only went down 100 psi
Old Oct 27, 2014 | 12:52 PM
SM105K's Avatar
I will be going this route with a boost leash and co2.
Old Oct 27, 2014 | 01:33 PM
Shoaf85's Avatar
Here is the link to summit racing page. Not sure if it's allowed so it may not stay up long. But when I bought my Boost/Pulse Leash the guy brought this kit to my attention for a street car option.
http://www.summitracing.com/parts/var-10000/overview/
Old Oct 27, 2014 | 02:05 PM
oscs's Avatar
That's awesome
Old Oct 27, 2014 | 02:13 PM
Chicago TDP's Avatar
I am interested too....but I drive my car EVERY DAY to and from work as well as around town in the summer time....wonder how that 2.5lb bottle would do...maybe just need to go to a bigger bottle for my car.
Old Oct 27, 2014 | 02:39 PM
oscs's Avatar
Here is the link to summit racing page. Not sure if it's allowed so it may not stay up long. But when I bought my Boost/Pulse Leash the guy brought this kit to my attention for a street car option. http://www.summitracing.com/parts/var-10000/overview/
Thanks
Old Oct 27, 2014 | 02:48 PM
oscs's Avatar
Hell at the rate given by 98camaro that 2.5lb would prob last you 6months. I'm debating on running just a 1lb bottle for my weekend needs.
Old Oct 27, 2014 | 04:10 PM
oscs's Avatar
I went ahead and bought a 2.5lb bottle and a regulator for $113
Old Oct 27, 2014 | 07:03 PM
LILHEMI's Avatar
i went ahead and bought a 2.5lb bottle and a regulator for $113
from where?
Old Oct 27, 2014 | 07:10 PM
oscs's Avatar
Originally Posted by LILHEMI
from where?
Some home brew supply place
Old Oct 27, 2014 | 10:30 PM
LS1PUNK's Avatar
The biggest problem with c02 is if you use the plastic line with push lock fittings. If you leave the bottle open and it leaks, your stuck with whatever spring you have in the gate as far as psi.
Old Oct 28, 2014 | 04:57 AM
95bowtie's Avatar
Has anyone ever used a nitrogen tank in a setup like the boost leash or ams?
I feel like you would get even more life out of that even. Plus you can get the tanks from the paintball store that are pretty large and very light.
If you have a paintball store near you as well you can usually get them filled, they never actually ise nitrogen it is always just regular ole compressed air except their compressor goes anywhere from 3000-4500 psi usually. The tank has a reg on top that brings it down to like 100psi.
Old Oct 28, 2014 | 05:41 AM
Camaro9969's Avatar
Just shut the bottle off when your not driving the car and it will last a long time. I love having the co2 boost is always perfectly flat
Old Oct 28, 2014 | 06:10 AM
oscs's Avatar
I'm using the Pushlok fittings and polyethylene hose. I'll be sure and shut it off.
Old Oct 28, 2014 | 06:12 AM
oscs's Avatar
Originally Posted by 95bowtie
Has anyone ever used a nitrogen tank in a setup like the boost leash or ams? I feel like you would get even more life out of that even. Plus you can get the tanks from the paintball store that are pretty large and very light. If you have a paintball store near you as well you can usually get them filled, they never actually ise nitrogen it is always just regular ole compressed air except their compressor goes anywhere from 3000-4500 psi usually. The tank has a reg on top that brings it down to like 100psi.
C02 has an expansion rate almost twice as much as nitrogen. You can fit more gas in smaller area
