What should I expect going from man pedal to auto
I've finally swallowed the jagged pill and decided to go automatic. My setup now works. I've got a clutch that hold, the Tick TR6060 trans, it works awesome. Car runs high 9's at 10-11 psi (data logged) through the exhaust, no 2 step just a 6800 rpm clutch dump. 1.43 60' with a 141.x mph. 4000 lbs car.
So I've decided to put a TH400 in it. At the same boost level what can I expect? Everyone says auto so....
Where you using a 2 step?
There is a few variables. With the correct spec'd converter and trans brake you can leave in the boost and it should pull a similar sixty. Maybe a bit better, maybe a bit worse. Also remember each time you shift it takes 1 to 2 tenths of a sec. It will be more consistent over a manual.
"I out shifted that automatic" - said no one ever.
No 2 step. Just drove it like it was N/A. I've got AFCO shocks out back. I should have no trouble repeating the 60' with an auto like you pointed out, if all is right.
I would but that requires modification to the trans tunnel. The TH400 is a direct swap and I don't have to mess anything up to go back to stick.
Your et looks decent for mph and 60. I doubt it will be a huge difference on the same power unless you really improve the 60ft imo
The manual is working for you. I'd keep it
I had been thinking put a wide open throttle box and a 2 step on then leave on 10 lbs boost. I feel that's all it will hook.
My considering the auto is also coupled with I will switch to an aftermarket computer for engine, boost, 2 step and all the other control they provide. I need more boost control which is why I only have low boost ET numbers. I just got AFCO shocks on the rear and I have only made 2 passes with them. I'm sure I need to work with them more.
I agree with rotary, it works, keep it. You can imorove on those times, maybe not go 8's like an auto(better chance at least), but it will be more fun. I love that you car is a stick, it gives it a cool factor.
Thanks guys. I love driving the stick shift. I see a low 9 (9.20's-9.30's) pass with this but not likely an 8. And that's turning the boost up getting a couple other things in order, dropping the exhaust, pull the air cleaners and piping, and so on. The problems are pig heavy car, and 26" tire. The 28" slick rubs my wheel openings front and back. Seems like the right boost control (progressive) with an auto would get the job done.
In my case I was running 10.44 over and over with a 1.47 - 1.50 60 foot leaving at around 7000 rpms. Trapped 131 - 132, car was consistent but broke drive line stuff non stop.
Went to a built th400 with transbrake with a b&m pro ratchet shifter. It's a nice setup, Was fun to drive still. I then ran consistent 10.39 - 10.41 with a 1.37 - 1.39 60 foot while leaving at 4500 rpms. My trap speed dropped to 128 mph, the car didn't stay hooked up as easy as it did with the 6 speed. Going into second gear it wanted to spin most of the time.
