made the swap to a glide.
Old Nov 3, 2014 | 08:17 PM
yenkomike's Avatar
Default made the swap to a glide.
well after much thought and the fact that I found a good deal on it . I pulled my 350 th out and went with a stock case glide with a manual valve body a 1.76 gear and a pro brake. now I need to relearn my launch but im sure it will like it. with the 350 th it was hard to get spooled and once the boost came it had a short 1st gear. this is my first glide now to see if I can run faster than my old trans with the same tune .
old trans ran
1.65 60'
6.84@103 1/8
and 10.54 @130 @10# boost.
I hope leaving with boost and a 1.76 gear it will run faster in the 1/8th and get me down to 10.20s or 30s at 10# boost. we will see.
Old Nov 3, 2014 | 08:27 PM
3 window's Avatar
You'll like it. Might take a little bit to get the gearing or converter figured out (if it even needs to be changed) but I'd say it'll be faster than the 3 speed. A glide has a lot less rotating mass than a th350. Easier to hook up a smaller tire as well. Good luck. Keep us posted.
Old Nov 4, 2014 | 06:34 AM
yenkomike's Avatar
I haven't driven it yet but I think the converter and gear will be good. my converter was a little tight down low so im sure the 1.76 will help with foot breaking but if not the trans brake will. lol. if the weather holds up I should get some street time by the weekend.
Old Nov 4, 2014 | 07:13 AM
SM105K's Avatar
I love my glide.
Old Nov 4, 2014 | 08:21 AM
Sleeperls's Avatar
I keep going back and forth on glide and th400. In for results.
Let me know how you like driving around town vs the old th350.
Old Nov 4, 2014 | 02:00 PM
SM105K's Avatar
For me it is great. My car is a 99.98% street car. My Glide works great on the street. I have the 1.76 first gear, 4300 stall, 3.42's in the rear with a 28 inch tall tire. It is pretty easy to hook up with 600 hp, and the car is so much fun to drive. One click and hang on.
Old Nov 4, 2014 | 02:11 PM
RonSSNova's Avatar
The nice thing is it's practically a bolt in for the th350. Stronger too.
I'll bet it drives fine. My th400 stays in low on the street for such s short time, it's like driving a 1.48 geared Powerglide anyway.
Curious how it performs at the strip. Next year? Or you still have a track open this late?
Ron
Old Nov 4, 2014 | 04:36 PM
yenkomike's Avatar
yes it was a bolt in but I had to do a little work to make trans shield clear the floor. I had to lower the rear about 1/2 inch and get the cable adjusted up but it is ready to give a try.
the tracks are still open but traction is an issue with cold track temps and the sun doesn't shine to much in November in Michigan.
Old Nov 4, 2014 | 07:10 PM
Sleeperls's Avatar
Long or short shaft?
Old Nov 4, 2014 | 07:52 PM
yenkomike's Avatar
std long shaft trans . same length as the 350 th .
I think the short ones were from the x frame impalas 62,63,64.they are a couple inch's shorter than any trans.
Old Nov 5, 2014 | 05:14 PM
yenkomike's Avatar
drove the car around today and to work and back about 20 miles . trans works great the 1.76 gear street drives good . I am going to make u bolts to hold up my traction bars so they don't slap when it shifts. car feels fast. it might just be the 45 degree air but it feels faster.
Old Nov 6, 2014 | 02:51 AM
stock48's Avatar
9 Second Truck Club
I really like my glide. A high $$$$ 3 spd might be faster but I Like having only one shift that doesn't come so soon, and it still has decent response even with 3.23 gears. Pulled my drag week trailer no problem too.
Old Nov 6, 2014 | 05:50 AM
yenkomike's Avatar
I think I can get a better more consistent launch and im sure my 10 bolt will live longer. my convertor was a little tight for foot breaking and now I can hold it back better. not to mention that I can t-brake it and leave as hard as needed .
Old Nov 6, 2014 | 01:33 PM
3 window's Avatar
Consistency will be huge, which will allow you to make changes and see what the car likes. My buddy had a '67 Camaro on spray that was super violent, very inconsistent and ran 8.30s-8.40s. He switched over to a glide, same converter, same tune up and the first pass, off the trailer, it went 8.10 and 8.07 on the second pass. The glide allowed him to bring in the power sooner and everything fell into place. This was on a 10.5W tire also, so the hit was a little softer on the smaller tire. Another friend of mine had a ton of power in a '68 Nova with a regular 10.5 tire and that car went consistent 9.30s on horsepower. We tried a th400, couldn't barely drive the car. Very violent. Small tires and heavy cars can be tricky to hook up once you get into a "bunch" of power. Good luck, I think you're gonna love it. I have a th400 in my Nova right now. We're gonna see how it is next spring, but I'm not opposed to a glide one bit.
Old Nov 7, 2014 | 05:09 PM
stock48's Avatar
9 Second Truck Club
Yea 3 spds are quicker if you can handle the power but you can only use so much tq on a small tire, and keep front end down. On a deal like my truck almost 5k lbs and 4x4 it loves the extra gear but I would he afraid of it in my car.
Old Nov 7, 2014 | 07:12 PM
yenkomike's Avatar
with the 350th there was to much gear to hold it back and I could only get 2100 rpm without pushing. then once I launched it whould go to 10# about a car or two out and I needed to shift right away . if my idea works I should be able to dial in how much power to leave on and have a set rpm for the t-brake and 2 step to get the best 60' and duplicate it to be consistant. I want to leave my 10# tune for now and work on the short times then see what it runs that way I think I can run 10.20s on 10# with a good 60' and I don't see any reason to turn it up until I get that working then a couple more #s will get me high nines im sure.
Old Nov 7, 2014 | 10:19 PM
3 window's Avatar
Keep reminding us you have a 5k pound truck that runs 9s! LOL! Just kiddin!
