Street Driven MWC 25.3 AES 427 Twin Turbo Glide E85 Build
#41
Motor is done and back from AES.
Will prob work on putting the long block together in the next week or so.
Picked up a Powerglide from Rob@chiseled. It's was redone by ATf to level 4 specs.
picked up a few other small odds and ends.
#52
Doing some test fitting.
sent my used endurex lifters to Comp Cams to be rebuilt. Once those come back, I can measure for push rod length and hopefully start buttoning it up.
Sold the QTP cover and picked up an edlebrock as the dart requires a Ls2 front cover.
Missing the valve cover bolts, contacted Allpro about ordering a set. One of the valve covers lightly touches the header, will need to clearance it.
went and visited the ole car at MWC, they got a few things done, but will hopefully get a bunch done now that Ray Lit's car is finished up.
Sold the VFN hood and going with one of TUFF's carbon fiber hoods.
#55
Decided to step it up. Purchased a pair of gently used Bullseye 88's.
Twin Bullseye 450-88's:
BatMoWheel
88x135 Comp wheel
96x88 Turbine
4" downpipes
1.30 A/R
Lightweight billet backplate
Polished SS exhuast housing
GO BIG OR GO HOME!
Selling the comp's if anyone is interested.
BatMoWheel
88x135 Comp wheel
96x88 Turbine
4" downpipes
1.30 A/R
GO BIG OR GO HOME!
