My 00 SS #3349 version 2.0
Step one was to acquire a 5.3, scored an lm7 locally with 110xxx:
I cleaned up the block and painted it:
Installed china studs, had a tick cam ground, ls7 lifters, 241 heads with prc .650's ls1 head gaskets, ls1 pan and a -10 drain bung
Painted the truck manifolds:
I will probably clean up the merge before final assembly:
Picked up an on3 7665...(I know, I know it's small and will have bp issues yada yada but I have it and am going to use it at this point until I can get something with an appropriately sized exhaust wheel)
Got the old motor stripped down:
Then took some mock up pics to check fitment while I still had a motor in:
And that is how the car currently sits^. Haven't had time to really mess with it this week nor the motivation to pull the hotside and charge piping back off of it to install gaskets, bolt torque converter up, install balancer etc but I might get to work on it tomorrow and will continue to update as progress is made.
