Cam Help
Old Dec 12, 2014 | 02:19 PM
neruve's Avatar
Default Cam Help
I am looking at a 4.8/5.3 (probably the 4.8) stock except for a cam swap/springs and car intake (for clearance issues) with one of the on3 7876 turbos. Manual, 3.55 gears and about a 3000 lb car. SD 60 lb injectors.
I have two trickflow cams already laying around I would like to use one:
30602001 - 216/220 @ .050, .560/.560 114 LSA
and
30602002 - 220/224 @ .050 .575/.575 112 LSA
Which cam would be the best choice for this and will the 60 lb injectors be enough.
Also hoping for 600-700 whp. Probably wanting a little high, is that much power possible with this setup.
Any rough guesses on spool time for the street?
Input would be great!
Old Dec 15, 2014 | 07:24 PM
neruve's Avatar
The smaller one seems to have -5 degrees of overlap while the larger one seems to have -1 degree of overlap so I think either or would be okay. Just not 100% sure.
Also I guess realistically 500-600 rwhp is a little easier goal but I would like to be over the 600 mark.
Old Dec 17, 2014 | 10:30 AM
Sales@Tick's Avatar
Use the 216/220 114 camshaft. Should see positive manifold pressure by 3000-3200rpm and full boost a little above 4000rpm with the stick. Maybe a few hundred RPM earlier or later depending on the tune up.
Old Dec 17, 2014 | 11:59 AM
neruve's Avatar
Awesome, thank you Martin. This is exactly the information I was looking for.
